Concrete Around Treated Fence Post Or Not? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-18-2009, 08:19 AM   #1
Send a message via Yahoo to ChimChim
Question
Concrete around treated fence post or not?
I live in southeast Ohio and want to install a privacy fence. Have heard by some that it is better to put concrete around the posts, and also have heard to use pea gravel or just dirt. Does anyone know the best way?
Thank you,
Jeff
ChimChim is offline   Reply With Quote
Old 04-18-2009, 08:27 AM   #2
crushed stone's my choice,,, conc hastens rot
yesitsconcrete is offline   Reply With Quote
Old 04-18-2009, 08:32 AM   #3
But will the crushed stone hold the post true & tight?
Old 04-18-2009, 11:08 AM   #4
CrossWorks's Avatar
Rewards Points: 150
This topic was brought up a couple years ago: http://www.diychatroom.com/f14/press...concrete-9218/
Good information!!
A great personality will open many doors in life,
but it's your character that keeps them open!
www.crossworksme.com
"Where Every Nail Has a Purpose!"
CrossWorks is offline   Reply With Quote
Old 04-18-2009, 08:04 PM   #5
Rewards Points: 1,016
I like to set posts in concrete - they stay solid and true for a long long time. I use the bagged concrete you mix right in the hole - pour in the contents of the bag, add water, mix.
I also like to use metal posts rather than wood (round with brackets for the wood attachment, or square/flush that can be covered with wood and disappear. Years from now when the fence boards need replacement, the posts will not...
Old 04-19-2009, 12:13 AM   #6
The only time I use concrete when installing wood fence is around the gate post.The key to a solid install is in the tamping of the dirt around the post.Once the post is in position add about 3 or 4 inches of dirt and tamp solid,repeat the process until you reach the top.
snake2k is offline   Reply With Quote
Old 04-19-2009, 12:26 AM   #7
One other thing I forgot to mention,if your installing a 4 inch post use a 8 inch auger bit.Using too large of a bit will cause problems.The least amount of earth disturbed around the post the better,also means less tamping.
Old 04-19-2009, 07:56 AM   #8
So basically...having dirt around the post will not make it rot...as opposed to concrete?
Old 04-19-2009, 08:00 AM   #9
ccarlisle's Avatar
The fact is is that concrete has a very alkaline pH and over time will degrade the wood fibres of the post. Nothing to do with 'rot' per se although it will look like, I dunno... termite damage.
We put roofing membrane around our posts and use concrete and stone at the base. Since you also deal with frost heave, you may not think either that just dirt is enough to counter the changing seasons.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 04-19-2009, 08:48 AM   #10
CrossWorks's Avatar
Rewards Points: 150
How about the best of both worlds...and I've done it this way. Tamp dirt for the first 3-1/2' and then add 6" of concrete at the very top. Look at it as a solid ring that will help stabilize the post. Just remember to put a strip of rubber membrane at that point around the post as protection from the crete. (Grace Ice&Water shield, you canget it at the Depot for 15-$20)
Old 04-19-2009, 09:21 AM   #11
i remember lots of cows who thought our barb'd wire fences were great & they were only split locust posts - no conc, no crush'd stone, no nuttin',,, our back yard fence's p/t 4x4 posts & boards - no stone, no conc, just dirt - 20 yrs old - still functioning !
you do what you want w/your fence !
Bad Concrete in Fence Post Holes - Advice? bcrenshaw Building & Construction 2 08-24-2008 12:21 PM
replace porch post on concrete slab maa40 Building & Construction 2 03-23-2008 11:50 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
Setting Fence Post cibula11 Building & Construction 2 06-22-2007 10:05 AM
Fence Post Problem cdubim Building & Construction 3 03-12-2007 02:09 PM
