Concrete Anchors - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-31-2011, 07:18 AM   #1
Rewards Points: 156
Concrete Anchors
Hello All,
I have a quick question. I am getting ready to build my knee wall on my basement concrete floor for my bar. I am going to build the wall out of 2x6. What is the best way to really anchor the bottom plate to the concrete. I normally use remshot's but I was thinking more of a bolt,nut combo since I want this to really suck to the ground. Sometimes with remshots they do not really seal super hard to the ground. As always I will have adhesive under the treated board but I do not want this thing to shimmy at all. Thanks
ryan5068 is offline   Reply With Quote
Old 03-31-2011, 07:22 AM   #2
There are quite a few concrete anchors, redhead anchors(expanding type anchors) are good for moderate to heavy loads and available at home/hardware stores.
Old 03-31-2011, 08:31 AM   #3
Licensed P.E./Home Insp
Aggie67's Avatar
Rewards Points: 802
Redhead wedge anchors are what I use when I need to anchor something to a slab or vertical poured wall - indoors. If it's outside, I stick with chem anchors.
Aggie67 is offline   Reply With Quote
Old 03-31-2011, 08:58 AM   #4
Rewards Points: 4,438
we use redheads inside OR out & don't have to worry about cleaning excess drill bit dust as much as when using epoxy,,, some eng's & arch's spec chem ( epoxy ),,, dot's & fed's usually spec 'poxies, too,,, shear strength is often more important to us than pullout
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 07:25 PM
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
Crumbling Front Porch - Part 2 - The Repair jerseyguy1996 General DIY Discussions 9 04-11-2010 07:11 AM
Filling sunken living room w/ concrete Q's phil. Building & Construction 5 07-10-2009 01:03 PM
Garage concrete and driveway asphalt repairs creamaster Building & Construction 4 07-12-2008 11:51 PM
