Concrete Additives - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-01-2008, 06:21 PM   #1
concrete additives
The concrete company says that I have the option of getting plasticizing additives as well as some type of fiber additives if I want.
What are the pros and cons of getting such additives?
In what way would density or other properties be effected?
ajoantmug is offline   Reply With Quote
Old 12-01-2008, 06:54 PM   #2
concretemasonry's Avatar
Rewards Points: 2,626
What are you trying to accomplish?
Your local ready-mix supplier should be able to give you what you need and cost differences.
Fibers are not a substitute for rebar. - PERIOD!!
Plasticizers are good for workability.
Fly ash is a retarder, especially in cooler weather.
Air entrainment is necessary for exposed concrete if you are in a cold climate.
superplasticizers are not for amateurs.
concretemasonry is online now   Reply With Quote
Old 12-02-2008, 06:18 AM   #3
dick's right, w/o knowing the application, can't tell,,, rebar adds strength during cure & after - fibers're useless far's i'm concerned but we use 'em when spec'd,,, different plasticizers, water-reducers, retarders, & accelerants all depend on final use,,, let your conc pro decide.
amateurs always think conc's easy 'cause good pro's make it look like it is
yesitsconcrete is offline   Reply With Quote
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 08:21 AM
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 09:38 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 04:48 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
