Concrete - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-23-2011, 05:27 PM   #1
concrete
Do you think i need to spend the money and time to put stone under concrete that I am poring in a basement that has no water problems , In a house over a hundred years old that has a dirt basement floor I'm already cutting a hole through the first floor just to get concrete down there, i am putting a plastic vapor barrier under the slab.
Rileyfravel is offline   Reply With Quote
Old 08-24-2011, 12:52 AM   #2
Rewards Points: 1,092
if u r positive there won't be water issues in the future, i'd say ok. do insulate under the slab, though, esp if you install floor heat.
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 01:32 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 02:56 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 12:12 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
House Main Drain Leaking under Concrete Tom738 Plumbing 0 06-01-2010 08:54 AM
