Concerns About My Drywaller - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-26-2009, 04:09 PM   #1
Rewards Points: 16
Besides the fact that the three day job is already at five days and one day they didn't even show, some things about the guy I've hired to do the drywall work on my kitchen remodel is bothering me.
He says the walls are ready to be textured, but I wonder. He states the outside corners around the window above the sink don't need a corner bead, just tape. I disagree since there were corner beads there when we took the kitchen apart.
I can see the tape through the mud on all the inside corners. Only one coat? He states that's ok because the texture will cover it. What about strength? And, if that's the case, why not do the same on all joints.
A little advice from the pros would greatly be appreciated.
nuckphoto is offline   Reply With Quote
Old 06-26-2009, 06:39 PM   #2
Rewards Points: 5,336
This guy is one of those,"oh, you don't need this", clowns. You need the corner bead on all outside corners and you need three coats of compound on all the surfaces. What you do next is up to you. Texture, prime and paint, etc..
These details should have been discussed before he even bid on the job. I'd tell him he can do it correctly or he can do it someplace else.
Ron
Footing for Block ontop of existing Fieldstone foundation. Concerns w/ work done.. slowjo Building & Construction 6 04-26-2009 11:17 PM
Fujitsu Heat Pump Concerns SanDiegoCool HVAC 3 03-19-2009 01:27 PM
backfill concerns morta General DIY Discussions 5 11-22-2008 08:17 PM
Concerns On Hardiplank Install ptra Building & Construction 2 04-23-2008 06:51 PM
Survey Results - Cavity Wall Insulation - Health Concerns mchu6am4 Building & Construction 5 03-14-2007 03:50 PM
