Concern With Bearing Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-14-2008, 10:22 AM   #1
Concern with bearing walls
I have a A frame Roof where all the supports are supported by the joists going across the width of the house, my concern is I'm trying to take down a 4 foot wall which would normally be a bearing wall but i was told with the an A frame structure I can remove that wall. Trying to confirm this piece of information.
giovannie is offline   Reply With Quote
Old 12-14-2008, 10:40 AM   #2
Need more details on where you are going to remove the wall. Pictures would be great.
There are several ways in which an A frame can be built and it depends on how yours was built. The size also makes a difference. A frames is a whole new ballgame when it comes to modifying them.
Are you saying that you want to remove an existing wall totally within the A frame and not part of the outside structure or any of the joists?
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
Bearing wall, HELP me please jamiedolan Building & Construction 7 11-03-2008 11:33 AM
Straightening Racked Walls smitty286 Building & Construction 3 03-11-2008 08:35 AM
Keeping Water out of the Top of Brick Walls o2barockstar Roofing/Siding 4 02-18-2008 02:50 PM
Roof Sag/No Load Bearing Interior walls mrkleyn Roofing/Siding 1 08-13-2007 10:00 PM
