Compromised Load Bearing Header - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-13-2012, 06:32 PM   #1
Rewards Points: 77
Compromised load bearing header
Was ripping down old paneling on a home I purchased a little over a year ago and I found this.
The first pic you see a double 2x10 where one 2x10 was completely vertically transected. The main load on this as you may see in picture 2 is a triple 2x4 vertically resting on the header besting the load of the main roof beam. They tried to transfer some weight using the single 2x4 on the flat which is resting on a properly supported triple 2x8 in the basement.
How can I properly reinforce this?
Compromised load bearing header-image-1622619158.jpg   Compromised load bearing header-image-2639066290.jpg   Compromised load bearing header-image-1679260991.jpg
Mikenra is offline   Reply With Quote
Old 03-13-2012, 07:05 PM   #2
Rewards Points: 528
You have a real problem, maybe.
I would suggest an inspection by a local engineer.
He could determine that the one 2x10 is sufficient, maybe not.
Sorry.
framer52 is offline   Reply With Quote
Old 03-13-2012, 07:22 PM   #3
Rewards Points: 626
Just looking at the photos. I can go either way on yes you got a problem! Or Nope you AJ Squared away go to go. How ever with out being there and really seeing what you have going on. If you have the ceiling sagging the door sticking etc might indicate problems. The best answer is to hire a structural engineer and have them give you their blessing.
On a side note I bet you wish you never tore in to that now? I know were your coming from. I have found all sort of WTF stuff hid behind the walls. Then I wished I never opend that up!
Nailbags is offline   Reply With Quote
The Following User Says Thank You to Nailbags For This Useful Post:
Mikenra (03-13-2012)
Old 03-13-2012, 09:37 PM   #4
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
Didn't you post this a couple months ago?
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 03-13-2012, 09:46 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,214
the squash blocks above the beam are pretty obvious.. the single stud below it is wrong.. it should be a triple also to properly carry the load from above
woodworkbykirk is offline   Reply With Quote
Old 03-13-2012, 10:56 PM   #6
Rewards Points: 77
Andy.
Certainly possible Andy, not sure. Getting some decent conversation this time around.
Old 03-13-2012, 11:00 PM   #7
Rewards Points: 2,212
Which would also have to be carried through in the basement or crawl space.
Best get someone n to look at it.
mae-ling is offline   Reply With Quote
Old 03-13-2012, 11:02 PM   #8
Rewards Points: 77
I have hired an Engeneering firm to check it out. I am always interested however, in what the DIY communities opinion is as well.
Old 03-13-2012, 11:53 PM   #9
AndyGump's Avatar
Rewards Points: 684
My opinion is that the hvac guy did a real hack job on this. No good excuse for it.
Andy.
The Following User Says Thank You to AndyGump For This Useful Post:
mae-ling (03-14-2012)
Old 03-14-2012, 01:59 AM   #10
Rewards Points: 626
Why? His opinion out weighs all our ideas combined.
Old 03-14-2012, 06:29 AM   #11
Rewards Points: 77
I guess because it's how I learn to look at things, what to look for and so fourth. Plus your post was great, "Aren't you glad you opened that wall" made me laugh out loud. I knew I was going to have to have an Engineer guy look at things but I saw no harm in getting your guys educated opinions as well.
Old 03-14-2012, 06:30 AM   #12
Rewards Points: 77
Andy.
Well said Andy. Reminds me of a Holmes on Gone show lol
load bearing wall removal ronnteresa Building & Construction 11 03-03-2012 12:39 AM
Removing part of a load bearing wall - what size header Mike Sch Building & Construction 1 01-09-2011 10:14 AM
Load bearing wall! Newtsjetson Building & Construction 2 12-19-2010 07:46 AM
Non load bearing wall door header? nocarpenter Building & Construction 10 06-11-2009 04:16 PM
Is this Load Bearing Wall remodel-virgin Building & Construction 16 05-11-2009 04:25 PM
