Old 09-28-2007, 08:54 AM   #1
always learning
compression
Hi all, I just finished the framming of my front porch with my cousin. My plan is to use fibreglass columns for support. There is a beam made up of 3 2 X 8 in the front that the columns will go under.
My question is what kind of board can I put between the beam and columns?
As I look around my neighborhood I see decorative wood between the columns and finish boards.
My concern is compression on a board that lays flat on its side.
theone is offline   Reply With Quote
Old 09-28-2007, 01:27 PM   #2
compression
How large is the porch roof?
Can you post a photo?
redline is offline   Reply With Quote
Old 09-28-2007, 01:37 PM   #3
always learning
compression
hey redline the 2nd floor roof/deck is 6'10" X 14'
I will take a pic when I get home
If you can imagine its a 2 story porch each with walkable floors but there is no roof on the 2nd floor.
Its just like this http://users.rcn.com/scndempr/dave/p...nsend/pt17.jpg
see where posts on the first floor meet the beam under the 2nd, I need to know what kind of board to use on the bottom part of the beam where the post/column meets it
I was thinking of 1 X 8 X 14 PT with routed sides for decoration
Old 09-29-2007, 04:43 PM   #4
compression
I use miretec. It's a composite with a wood grain finish. Also holds paint well and doesn't rot like wood. In the picture below, we wrapped all the posts and beams with it.
97catintenn is offline   Reply With Quote
Removing compression ring? ruzz Plumbing 30 10-01-2011 07:14 PM
Pex/Qest Compression Fitting Logback Plumbing 9 09-03-2010 10:32 PM
How to connect non-threaded 1/2 inch CPVC to a compression shut-off valve andy Plumbing 6 12-12-2006 10:02 PM
compression valve farrington135 Plumbing 6 04-24-2006 02:38 PM
installing compression valves markymark Plumbing 2 08-11-2005 11:03 PM
