Composite Vs Wood Deck Screws - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-03-2009, 12:07 AM   #1
Composite vs wood deck screws
Redwood deck. My contractor installed composite deck screws on my redwood deck. He is now attempting to remove them,and use the appropriate wood deck screws. The problem is they (composite screw)are stripping. How important is it to use the appropriate screws? He wants to leave them in, too much work. He cut the composite screw from underneath and left the deck unattached in places. The deck creaks when walking in areas of cut screws.
cranedk is offline   Reply With Quote
Old 08-03-2009, 10:44 PM   #2
Registered User
Termite's Avatar
Left alone they probably wouldn't have been too much of a problem. Now that they're cut that's certainly not the case. Sounds to me like your contractor has a problem on his hands.
Wood deck screws have bugle heads on them which are wider, allowing the screw to grab more surface area. That's beneficial because wood sometimes has a tendency to cup, move, warp, twist, etc. The small heads on composite deck screws could potentially allow the wood to move a bit more, albeit unlikely.
Personally, I'd insist on replacement with the correct screws for the product being used. Your redwood deck was undoubtedly expensive so you should get what you're paying for.
Old 08-04-2009, 12:07 AM   #3
Registered User
Rewards Points: 5,514
All nails, fasteners and hardware must
be stainless steel or top-quality, hot-dipped
galvanized (electroplated galvanizing is not
acceptable). Poor quality fasteners will
react with redwood’s natural, decay resisting
extractives causing unsightly stains.
http://www.deckindustry.org/40materials.htm It doesn't sound good. Unless they are stainless steel...... Be safe, G
Old 11-26-2015, 01:48 PM   #4
Rewards Points: 12
Why is he back trying to remove them? What went wrong?
StreakersQB is offline   Reply With Quote
Old 11-26-2015, 02:05 PM   #5
Wildbill7145's Avatar
Rewards Points: 162
6yr old post. I'm sure the issue was resolved.
Wildbill7145 is offline   Reply With Quote
Old 11-26-2015, 02:12 PM   #6
Rewards Points: 12
Haha wow, how the H did that happen?
lol thanks!
The Following User Says Thank You to StreakersQB For This Useful Post:
Wildbill7145 (11-26-2015)
Old 11-26-2015, 03:47 PM   #7
Rewards Points: 1,232
lol thanks!
The old adage -- "The Hurrier I Go, The Behinder I Get" -- comes to mind and I suspect he is still attempting to remove those screws that were forced in with some kind of hammer drill driver.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Msradell (11-26-2015)
TREX decking extremely disappointing KHL General DIY Discussions 266 07-05-2013 11:26 AM
pressure-treated wood for deck joists? beiley Building & Construction 16 02-26-2013 07:27 PM
Composite deck building question Big Marino Carpentry 6 12-31-2008 10:14 PM
failing miserably at screwing in 2 inch deck screws gordie howe Carpentry 17 10-28-2008 11:00 AM
DECK decking nails vs screws ... christian15213 Building & Construction 8 05-02-2005 07:51 PM
