Composite Vrs. Wood Deck Materials - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-20-2009, 02:46 PM   #1
composite vrs. wood deck materials
In the process of installing a new deck and evaluating the pros & cons of wood & composite decking materials. The new deck will be on a southern exposure with full sun. There appears to be many composte deck manufacturers out there. Are some better than others? Initial research indicates all composite decking is not as low maintenance as one would initially think. Mold, staining & fading tend to be a significant problem, requiring washing several times a year. Does anyone have any feedback/ recommendations??
rcassidy is offline   Reply With Quote
Old 04-20-2009, 05:08 PM   #2
knewbie
curapa's Avatar
Being in full exposure of the sun you will likely have a fading issue but not have to worry about mold. To avoid any of these issues you may want to consider a PVC decking rather than composite. PVC decking generally does not stain or fade. I hear great things about CorrectDeck. As for composites I would recommend TimberTech.
If your budget allows, IPE is a great choice if you do not mind some occasional maintenance.
ParkerFenceandDeck.com
curapa is offline   Reply With Quote
Old 04-20-2009, 06:33 PM   #3
Since you already have decided on a higher budget for the composite decking, why not go with a SA hardwood like ipe or mahogany? The price will be comparable if you are doing the work and it will look much nicer and hold up better than any composite decking. Added is the fact that there is very low maintenance.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Building new deck and screened in Gazebo - Wood or Composite? Todd1 Building & Construction 10 11-05-2010 11:24 AM
Comment on those Special Type of Treated Wood for Deck ? KUIPORNG Landscaping & Lawn Care 4 07-04-2006 12:38 PM
