Old 11-05-2012, 10:43 AM   #1
Composite Decking
Can composite decking be installed on top of an existing deck or do the old deck boards have to be removed
denban72 is offline   Reply With Quote
Old 11-05-2012, 11:14 AM   #2
Composite Decking
If you want a really moldy mess and rotting wood under the new decking that would be the way to do it.
Remove the old decking, inspect the old floor joist.
Composite decking need the floor joist to be no more then 16" apart, if your going diaginal then they need to be no more then 12" apart.
Here's a cool tool I found that makes fast work when it come to ripping out decking boards.
I found mine at Northern Tool.
http://www.thegutster.com/
The Following 2 Users Say Thank You to joecaption For This Useful Post:
moneymgmt (11-05-2012), woodworkbykirk (11-05-2012)
Old 11-05-2012, 04:15 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Composite Decking
just what joe said.. i had to replace composite decking on a deck built 2 years ago.. the joist spacings were all over the place and half werent even fastened properly.. had to add extra joists because the decking was running on a 45.. the old decking was saggin in the heavy traffic areas
woodworkbykirk is offline   Reply With Quote
Armadillo Composite Decking by Rhino eayost Building & Construction 1 06-18-2012 09:53 PM
Replacing deck with composite decking, good or bad? rjohnson84 Building & Construction 2 07-25-2011 01:00 PM
I'm looking for White composite decking... Anyone? Lightning Remodeling 1 05-25-2009 05:48 PM
Composite decking question BigJimmy Carpentry 5 09-20-2007 10:59 PM
Composite decking question BigJimmy Building & Construction 2 07-09-2006 09:23 AM
