-   -   Composite Decking (http://www.diychatroom.com/f19/composite-decking-162255/)
denban72 11-05-2012 10:43 AM
Composite Decking
Can composite decking be installed on top of an existing deck or do the old deck boards have to be removed
joecaption 11-05-2012 11:14 AM
If you want a really moldy mess and rotting wood under the new decking that would be the way to do it.
Remove the old decking, inspect the old floor joist.
Composite decking need the floor joist to be no more then 16" apart, if your going diaginal then they need to be no more then 12" apart.
Here's a cool tool I found that makes fast work when it come to ripping out decking boards.
I found mine at Northern Tool.
http://www.thegutster.com/
woodworkbykirk 11-05-2012 04:15 PM
just what joe said.. i had to replace composite decking on a deck built 2 years ago.. the joist spacings were all over the place and half werent even fastened properly.. had to add extra joists because the decking was running on a 45.. the old decking was saggin in the heavy traffic areas
