Composite Deck Boards -- Is One Screw Enough - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-17-2012, 08:25 PM   #1
Composite Deck Boards -- Is one screw enough
I just did a new deck and--for God knows what reason--I used just one screw at a time to fasten the boards to the joists.
I know it's typical to do two screws on each joist, but am I screwed (pun intended) by using just one.
FYI: I have 12" joists, 1" composite boards, and 2" exterior screws.
tobingrant is offline   Reply With Quote
Old 07-17-2012, 08:31 PM   #2
Rewards Points: 12,868
Always 2 screws !
And what do you mean by exterier screws? That could mean a lot of things.
Does it say ACQ approved right on the box? If not there the wrong screws.
Most often I use 3" ceramic coated decking screws, and put them in with an impact drill driver.
tobingrant (07-17-2012)
Old 07-17-2012, 08:36 PM   #3
Dammit--but what's going to happen if
a) leave it as is
or
b) at least wait a few months for the weather to cool off a bit before I go back and redo it
Old 07-17-2012, 08:48 PM   #4
It's not going to fall down but those boards will work there way loose.
Old 07-17-2012, 08:49 PM   #5
DIY staff
Rewards Points: 7,174
The boards may cup a bit--but should be pulled back to flat when you add two screws in the proper position---
Make sure the screws are ACQ compatible---the chemicals in the wood are very corrosive.
Old 07-17-2012, 08:54 PM   #6
Davejss's Avatar
Rewards Points: 740
Hidden fasteners have been my choice, and my customer's choice lately. But in your case I would certainly add the second screw. If you put one in the center you'll probably end up having to remove it and then install the two screws in accordance with the manufactuer's instructions.
It's tough on the back but it will be well worth it.
Davejss is offline   Reply With Quote
The Following User Says Thank You to Davejss For This Useful Post:
Old 07-17-2012, 09:02 PM   #7
Thanks! I was hoping for better news, but I'm definitely going to re-do the screws.
Old 07-17-2012, 09:29 PM   #8
If you only put one in the middle then your stuck removing that one and installing three so there is not a hole left in the middle, or an odd ball headed screw showing.
If you use composit decking screws, there going to have smaller heads and not shows as much.
Tags
composite , deck
Underdeck shed , can i roof w/pt plywood & put deck boards to it? BigTy General DIY Discussions 6 05-25-2011 02:45 PM
Regain luster on composite deck Woodcutter General DIY Discussions 1 05-23-2011 03:12 PM
Deck Access Hatch rman1953 Remodeling 7 07-11-2010 06:44 PM
how to attach composite deck to steel TazPapa Building & Construction 3 05-31-2009 09:45 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
