Compatible Caulk? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-23-2008, 12:59 PM   #1
Compatible caulk?
Howdy,
What type of caulking would be compatible with 15 lb building felt and the nailing fins on vinyl windows?
Thanks for your help.
Solar Dave
Solar Dave is offline   Reply With Quote
Old 02-23-2008, 02:40 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Hi Dave,
Window nailing fins are generally not caulked or siliconed, unless spcified by the window manufacturer.
They are most often overlaid with water and Ice shield strips, or other brand of flexibale flashing. There is a process to layering each strip.
LINKS (examples):
http://www.intlwindow.com/pdf/instal...onstr_inst.pdf
http://www.silverlinewindow.com/pdfs/nc_instruction.pdf
- Build Well -
Old 02-24-2008, 04:38 PM   #3
Thanks Atlantic WB Const
The reason I asked the question is that during the time that I was considering which house wrap material to use, I downloaded the instructions for wrapping windows from the Tyvek site and they show running a bead of caulk along all three jambs and not the sill after you have applied the stick on flashing to the exterior sheathing. Would you say that this is not correct? I want your opinion.
I downloaded the two articles you gave to me and will study them carefully.
I am retired and living about 13 miles from the Canadian border near Bellingham WA. I am about to build a new solar home that has a radiant concrete slab floor powered by a geo-thermal heat pump. It will have lots of windows on the south side and I am being very careful to do the research ahead of the tasks so they are done correctly.
Thanks again for your help. I really appreciate it.
Cheers,
Solar Dave
Old 02-24-2008, 04:45 PM   #4
Hi Dave,
Some manufacturers call for silicone. That would be the sealant to use.
- Build Well -
How to caulk windows the RIGHT WAY? fritzycat1 Painting 3 09-10-2007 06:32 PM
Condensation on Metal Window Frames: Should I Caulk? xquercus General DIY Discussions 6 06-29-2007 09:24 AM
Bathtub Caulk billinak Remodeling 17 05-27-2007 08:34 AM
Caulk Windows eric s General DIY Discussions 2 11-26-2006 08:45 PM
