Columns / Roof - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-05-2006, 10:43 AM   #1
oar
columns / roof
Hi all,
I have to span a square of about 50 by 50 feet with a roof. The roof should have a cupola in the middle.
I am wondering if I can simplify construction of the roof and reduce cost by putting up four columns arranged in a much smaller square in the middle of the larger square. These columns would form the base of the cupola and allow me to eliminate large and complex trusses by having rafters running from the exterior wall to the columns and tying into the columns directly.
If I do this can I achieve significant cost reduction in the construction of the roof.
I do believe that a column supported roof would be significantly sturdier.
What do you think?
oar is offline   Reply With Quote
Old 12-05-2006, 11:16 AM   #2
concretemasonry's Avatar
Rewards Points: 2,578
columns / roof
Sounds to me you would be better off (and cheaper probably) to give all your information to a professional and have him sort out the options.
He will need to know where your are for exterior loads, wind and sesmic. Since it does not sound like a normal use, the floor loads could be different than normal.
Your system could certainly hold up a roof, but it might not be the best or most econominal.
I see a lot of low cost buildings built with trussed roofs spanning 50' every day. Some even have coupolas. Much depends on your coupola requirements.
concretemasonry is online now   Reply With Quote
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 10:44 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 08:28 AM
flat roof leak snikda9 Roofing/Siding 16 01-26-2006 05:25 PM
Need Help on the Flat Roof and more... MelindaA Roofing/Siding 12 12-21-2005 11:12 PM
