Coloring Existing Grout - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-24-2011, 02:23 PM   #1
coloring existing grout
I recently tiled my kitchen floor. I don't like the color of the grout as much as I thought I would, so I am thinking about using epoxy paint(from tile store) to darken it up a bit.
I was looking to find out any info(negative or positive for this approach).
I mixed sealer in the grout before applying, and was also wondering if that will make any difference at all for the epoxy to adhere?
redmanblackdog
redmanblackdog is offline   Reply With Quote
Old 02-24-2011, 04:42 PM   #2
Rewards Points: 1,520
Suggest you repost your question here:
http://www.diychatroom.com/f5/
Or a moderator can move it.
bob22 is offline   Reply With Quote
Old 02-24-2011, 05:21 PM   #3
Thank you Bob, I was up late last night. Not quite a 110% today!
Old 02-24-2011, 05:58 PM   #4
Rewards Points: 5,336
redmanblackdog
Try using an enhancing grout sealer on a sample and see if this works for you. It will darken the grout up a bit.
Painting the grout would not be my choice.
You can avoid this issue in the future if you take scraps of tile and grout them before you do the floor. I do this whenever I do a tile job. It helps them to pick a color if they have a few choices in mind.
Ron
Re-grouting tile kitchen counter top bigbearbear General DIY Discussions 15 01-18-2011 02:38 PM
Shower Floor Grout Prob. MEH Tiling, ceramics, marble 1 11-05-2010 08:55 PM
join new crawl space CMU footing/foundation to existing CMU basement wall CapeCod153 Building & Construction 4 08-04-2010 08:35 PM
coloring tile grout gginkansas Flooring 7 12-13-2009 04:27 PM
Sealing Grout qvminich Building & Construction 4 08-24-2008 06:56 PM
