Colored Stamped Concrete Floor Repair - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-12-2011, 10:45 PM   #1
Colored stamped concrete floor repair
3 yrs ago we had colored stamped concrete poured for the floors in our basement. We recently removed a wall to open up the family room to discover that it must have been done in 2 pours as there is a 1/4-1/2 inch gap between the floors in those 2 rooms. It is very unsightly. Is there a way to have a concrete threshold made or poured to cover the gap between the floors? If not, is there any suggestion on what we can do to cover this gap?
audraem is offline   Reply With Quote
Old 03-13-2011, 08:21 AM   #2
Rewards Points: 4,438
easiest, least expensive, & proper way is to install backer rod & seal it,,, sika makes joint sealants in colors
Old 03-13-2011, 10:52 AM   #3
Thank you for your quick response! I forgot to say that there is radiant heat under the concrete floor. Will this make a difference in the sealant we use?
Old 03-13-2011, 10:54 AM   #4
UNDER the conc OR IN IT ? ? ? no, no difference in sealant but suggest you pick a dark color
Old 03-13-2011, 01:25 PM   #5
The radiant heating is pex tubing on a bed of sand and then foam insulating panels. I absolutely love it. The concrete is stamped and multicolored to look like large paver stones.
Stamped concrete kathy103 Landscaping & Lawn Care 10 10-27-2011 07:51 PM
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 09:47 PM
updated pics of stamped concrete curing amandalc04 Building & Construction 20 06-01-2010 10:50 PM
prices for stamped and stained concrete scorpione General DIY Discussions 1 08-04-2009 08:02 AM
concrete washed on existing stamped concrete morta General DIY Discussions 2 10-10-2008 10:58 AM
