Collar Tie Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-07-2010, 01:41 PM   #1
Collar tie question
IIRC the collar tie can only be moved up 2/3 the length of the rafter, correct? Is this measurement to the center of the tie, or the bottom of the tie?
In other words, if I'm trying to determine what my ceiling height will be after the installation of the collar ties, after I determine 2/3 the rafter length to get an elevation, do I then have to subtract 1/2 the collar tie stock width to know the ceiling height - or can I run the bottom of the collar tie at 2/3 the rafter length?
TIA
DyerWolf is offline   Reply With Quote
Loose Collar Tie nofx1981 Building & Construction 6 02-09-2010 08:40 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 10:17 PM
Roof Sagging wall bowing christy123 Carpentry 37 12-29-2006 04:16 PM
Removing Collar ties Mike2004 Building & Construction 6 12-16-2006 01:48 PM
