Cold Weather Concrete In Post Hole OK?? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-24-2008, 06:01 PM   #1
Cold Weather Concrete in Post Hole OK??
Hi,
I have a fence company stating that it's ok to pour concrete, without putting any additives into it that I've heard about, into post holes that will be dug to accomodate my new fence.
I've heard that concrete will not maintain it's optimum strength if it freezes but I can't seem to get a straight answer from anyone.
The fence company says that since the hole is "underground" the 30 degree temperatures we've been having lately don't matter. Is this true? Should I wait until the spring since I'm in NJ?
I thought there was some sort of additive that you can add to help solve this problem.
Any help would be appreciated.
Thanks.
Jerry
Jerrycast is offline   Reply With Quote
Old 01-24-2008, 06:57 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,736
Ayuh,... That ain't that Cold,.....
And,....
You're sinking Fence Posts,.... Not pouring a Bridge.....
I'd get'er Done,+ Not look back..........
Bondo is online now   Reply With Quote
Old 01-24-2008, 10:00 PM   #3
Ok, thanks. I was just hoping this fence won't "lean" years later when I'd then regret not being patient and waiting a couple of months.
I keep reading that if the average temp is below 40 degrees three days in a row it's not a good idea.
But, since your a Master Re-engineer. What is that anyway?
Old 01-25-2008, 01:01 AM   #4
ICF Construction
If you are really concerned buy some straw and spread it around the top of the concrete when they are done pouring, the concrete at the bottom is not going to freeze and to top it off, it's not structural, as Bondo said, it's a fence not a bridge
Chris
Chris Johnson is offline   Reply With Quote
Old 01-25-2008, 05:45 AM   #5
Bondo's Avatar
Just a play on words Jerry,.....
While I sometimes create things from scratch when I need to,....
I spend most of my efforts at Rebuilding the things in my life.....
With my houses, it's Re-engineering for my Comfort,.....
With my toys,... It's usually Re-engineering for Easier access to normal service items,...
And Comfort of course....
It's been somewhat of a Curse all my life,.....
I don't think I own Anything at all that is the Same as when I bought it......
Good Luck with your fence........
Old 01-25-2008, 06:46 AM   #6
Thanks Chris and Bondo (Bondo? anothe play on words??).
Yeah, I want this fence "now" for my dog to have some freedom to play, but since the split rail triple rail fence is going to be the the top of a hill behind my house (with the hill continuing up further behind the planned fence postition) I was worried it wouldn't last as long if done now during the winter here in NJ.
So, I'll try the straw idea and go forward I guess.
If I understand correctly, I should just have hot water for them to mix the concrete with, right?
Thanks again.
Jerry
www.jerrycastaldo.com
Old 01-25-2008, 09:47 AM   #7
Bondo's Avatar
Ayuh,.... A play on My real name......
Pressure treated posts set in concrete? zubin6220 Building & Construction 19 08-13-2013 05:39 AM
Proper Post on Concrete Procedure Dallas Building & Construction 3 01-05-2008 07:20 AM
Hole in the concrete slab shapeshifter Flooring 5 10-15-2007 06:45 PM
Post in or post on concrete cibula11 Building & Construction 5 06-07-2007 09:39 PM
how cold is too cold for concrete flatwork THEBIGPUNN Building & Construction 2 12-24-2005 02:55 AM
