Cold Weather Caulk - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-02-2010, 10:45 PM   #1
I=E/R
a7ecorsair's Avatar
Cold weather caulk
I'm in the process of building a new house and have some exterior caulking to complete but it's cold around here. What caulking products has anyone used with good results in below freezing but above zero temperatures. I'm 45 miles from anything so I'd like to get some upfront information before my next trip into town..
a7ecorsair is offline   Reply With Quote
Old 12-03-2010, 06:21 AM   #2
KCB
Use a caulk with a rubber or silicon base. Latex caulk will just freeze before it can set up, so don't use latex . Ensure the substrate is clean and dry .Use a hair dryer/heatgun etc... to melt ice dry moisture and warm the substrate or clean the area with acetone or methyl ethyl ketone and a clean cloth. Cleaning will not only remove the ice if any, but also ensure the substrate is clean.Do it on a sunny mid day , the sun will heat up the substrate more than you think.
KCB is offline   Reply With Quote
Old 12-03-2010, 10:58 AM   #3
Depending on what you're caulking, I would suggest Quad Advanced Formula Window, Door and Siding Sealant. We're using this on our house (very cold right now) and the stuff is probably the best caulking I've ever used.
AgentW is offline   Reply With Quote
Old 12-03-2010, 01:01 PM   #4
Rewards Points: 1,528
I've no ax to grind on this:
DAP 3.0 Advanced All-Purpose indoor/outdoor sealant is ideal for sealing windows, door frames, corner joints, siding, trim, butt joints, baseboards, molding, pipes, ducts and vents. It's available in White and Crystal Clear, which offers superior clarity that allows the beauty of the surface to shine through the sealant. Plus, it adheres to just about any surface like wood, metal, brick, glass, vinyl, aluminum, concrete, masonry, plaster, drywall, stucco, stone and painted surfaces. DAP 3.0 is the best of the best in all-purpose indoor/outdoor sealants.
  • Caulk and expose to water after just 3 hours without washing out.
  • Permanent waterproof and weatherproof seal.
  • Cured sealant that's mold and mildew resistant.
  • Outstanding flexibility and adhesion to wide range of substrates without cracking or shrinking.
  • Indoor/outdoor use.
  • Extreme weather and temperature application range: -35F to
    140F (White), -35F to 120F (Crystal Clear).
  • Low odor and low VOC content.
  • Superior paintability.
  • Lifetime guarantee.
bob22 is offline   Reply With Quote
Old 12-03-2010, 06:35 PM   #5
I=E/R
a7ecorsair's Avatar
Thanks everyone for the responses. At least know I have some choices
Old 12-04-2010, 11:34 AM   #6
I=E/R
a7ecorsair's Avatar
Old 12-05-2010, 04:29 PM   #7
Definitely try polyurethane.
ConcreteTreat is offline   Reply With Quote
Recaulking at previously silicone-caulked shower door frame hffeagan Kitchen & Bath Remodeling 36 02-24-2016 03:01 PM
Installing a roof in cold weather papageek Building & Construction 6 11-03-2010 11:57 AM
CFLs and Cold Weather Jazan Electrical 3 02-19-2010 12:09 PM
Tiling in cold weather pglc Flooring 3 11-20-2009 06:13 PM
Cedar Decking and Cold Weather project_guy Building & Construction 3 01-29-2009 06:32 AM
