-   -   Cold Storage Room Help (http://www.diychatroom.com/f19/cold-storage-room-help-112743/)
Gwen4280 08-02-2011 01:37 PM
Hello, we have a cold storage room in our wood basement, but it doesn't get cool enough to keep potatoes from sprouting and getting soft over the winter, we live in Saskatchewan Canada so the winters are anywhere from - 15 celsius to - 30 at the coldest.
I am looking for information on what to do to make our cold room colder... the walls are finished with gyproc and also insulated, we have one 2" or 3" pipe that we put in to get some cold air in from outside, but it's not helping very much.
Hope you can help us....
Gwen4280
Broughton 08-02-2011 01:40 PM
My goodness that's cold. I can't even imagine that. Can you build a little box outside to keep them in?
GottaFixIt 08-02-2011 02:30 PM
Since you have an inlet from the outside already. I'd add a vent fan and duct it to near the floor on the opposite side of the room. This will draw air in through your passive vent and chill the room. You could use a thermostat (temp controller) on the fan to control the temperature.
Gwen4280 08-02-2011 10:20 PM
Nope that wouldn't work as they would freeze. And we usually have about 100 to 200 lbs
Broughton 08-02-2011 10:23 PM
Gottafixit gave you a great idea, what about that?
Gwen4280 08-02-2011 10:23 PM
I'm not exaclty sure what you mean... can you explain a little more.... ie what kind of a vent fan you mean.
The other thing is, the wall oposite the inlet is an inside wall, will that still work? Thanks
Broughton 08-02-2011 11:08 PM
It would just be a little fan in a box that you would mount over the inlet on the wall. It is like the vent fan in your restroom. It would bring in cold air from outside and blow it on your taters.
tuchodi 08-03-2011 08:24 AM
Gwen4280
I have a wooden basement also and have a cold room in the corner it has a dirt or sandy floor. I use a Dryer vent to bring the cold air in from the top of the wall and also use and elbow inside with a piece of 6' vent pipe to get the cold air down to the floor. I also have a vent at the top coming out of the room on the opposite wall to expel warmer air. I have a damper on the incoming vent to regulate the cold air coming in and it has worked great for years. My basement or 7' crawl space is not finished just use it for storage and a cold room. You may have to put a larger vent coming in.
Gwen4280 08-03-2011 06:20 PM
Thanks for all your help... I was wondering if it would work if we put in another inlet on the other side of the room... (we have one inlet on the south side, the only other outside wall is on the west side of the house), would that also work, or do we need the fan?
Broughton 08-03-2011 06:30 PM
Most likely a vent fan is the best option. I don't envision lots of air movement at that right angle. It's also aimless since you don't have to pierce the exterior envelope again.
tuchodi 08-04-2011 09:40 AM
I don't think it matters which wall you put the vent on mine is on the north wall and I keep vegetables in it all winter until the summer and no problem. When June comes along most of my vegetables are eaten and of coarse are a little soft. Do you have a dirt floor? From all my research that seamed to be the biggest problem with keeping veg a long time, they seam to do not very well if you have a concrete floor.
Gwen4280 08-07-2011 12:33 AM
We have a cement floor... our old house also had a cement floor and potatoes kept very well in there.. right up till May or June.
Gwen4280 08-07-2011 12:34 AM
Thanks for your help!! :thumbsup: Will definately have to try the vent, hopefully that works well! Thanks again!!
