Cold Storage: Drywall Over Exterior Poured Concrete Walls? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-17-2012, 12:55 PM   #1
Question
Cold storage: Drywall over exterior poured concrete walls?
I'm trying to finish my cold storage room and at first wanted to parge the concrete walls, but it turned out quite difficult, so I'm exploring other options.
Due to the small size of the room (only 5' wide, but 20' long), I would like to avoid framing it with 2x4s which would take away a lot of space. I do not want to insulate it either (it's a cold storage room anyway).
Can I mount drywall over the concrete wall? If so, would I use furring strips (e.g. 1/2") to create a small gap between the concrete wall and the finished wall? I'm concerned about using wood furring strips directly against concrete. Although I don't have water issues, I suspect they would rot over time. Are there alternatives? What about vapor barrier?
Or should I use cement board and furring strips not made out of wood (not sure if anything like that exists)? Can I mud over cement board (to add a texture) and paint over it?
I appreciate any suggestions/concerns.
TomU is offline   Reply With Quote
Old 11-17-2012, 01:57 PM   #2
Rewards Points: 13,270
No, no and No.
If it's just a cold storage room why fancy up the walls.
A few coats of Dri-Loc and wiping over it with a 14" drywall knife will smooth it out and help to keep it dry.
Old 11-19-2012, 12:45 AM   #3
Rewards Points: 1,092
+1 for joe's response. can i hang my moose in there next fall?
Old 11-19-2012, 01:31 PM   #4
AGWhitehouse's Avatar
+2 for joe's response...
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 05:37 PM
Removing drywall that's glued to concrete calcnerd Building & Construction 6 06-23-2011 06:46 AM
What's the best way to remove Plaster/Lath walls and replace with Drywall psubaron Building & Construction 31 02-14-2011 12:20 PM
Wet Concrete Walls: Painting apartments in China szstevo Painting 9 01-03-2010 11:04 PM
Insulating Cold Storage below slab porch Chemist1961 Building & Construction 1 12-09-2009 09:20 AM
