Cold Rooms - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-27-2010, 08:21 AM   #16
the way i read that post is there is an unfinished room above with the insulation blown on the floor. also that the rim joists are uninsulated all of which means air in at eaxterior wall plane. yes?
The older I get the better I was
Old 02-27-2010, 08:51 AM   #17
Rewards Points: 640
The room is on the main floor... the 2nd floor, they never finished the room so it is just blown in insulation laying on the joists and drywall with no vapor barrier... the basement has rim joists that are not insulated in anyway at all... (on my list of things to do this summer right now)
BlueBSH is offline   Reply With Quote
Old 02-27-2010, 08:56 AM   #18
depending on how well the walls are insulated the basement may be creating a chimney effect wanting to pull air from above. also if the top of walls in unfinished room has pipe/electrical penetrations that arent sealed this is another entry point. just a thought
Old 03-01-2010, 03:04 PM   #19
Rewards Points: 640
Not sure how much those cause it.. the walls are built out of 2x6's and has R-19 insulation (fiberglass faced batts) anywhere there is a line going into a wall there is also spray foam around it to seal it up... I think my biggest problem is the unfinished room upstairs and a rimjoist on the west side of the house right below this room that I cant get to... there is about a 1 inch gap between the top plate of the 2x4 wall in the basement and the cavity the rim joist creates... but you can definatly feel cold air blowing out of it on windy days... I just dont know where its getting in besides the gas line that enters the house on that side... but upstairs there is a ridge vent, a octagon side vent and of course all the soffet vents... the ceiling is not insulated, it's just exposed rafters so cold air moves freely in the room upstairs...
Old 03-01-2010, 04:14 PM   #20
Thumbs up
Blue BSh. My inclination was to answer you about checking the (outside) walls. But you exclude that in your answer. My own experience was with two rooms facing outside walls that were never warm in spite of the radiated heat working almost constantly. The solution was in framing out both rooms and inserting R-19 Insulation. Both rooms turned into the warmest in my house.!
spark plug is offline   Reply With Quote
Old 03-02-2010, 10:09 AM   #21
Rewards Points: 640
Here's what the room upstairs looks like (its an unfinished space that has a door into it like all the other rooms upstairs, According to the house plans this should of been a bedroom with a large dormer on it, but they never put a doormer on and just left it at the floor joists and filled it in with insulation and put a vent in)
This room is 30 ft wide (if you go from the end of the roof to the other end, its about 28 ft if you go by internal space only), 22 ft long and has a 8/12 roof pitch... anything that stands out in the pic as something that I can door to help any from the top down?
Old 03-02-2010, 10:21 AM   #22
Originally Posted by BlueBSH View Post
two sides are exterior walls...
there is a sliding door (about 76x80 inches) and a single window (about 34x40) but I don't feel any drafts coming from them or around them...
From experience; I have two rooms that are close to what you describe. I couldn't feel any drafts. I reluctantly covered the sliding doors and the windows with the plastic film window kits. The difference in room temp was amazing. Easily 6-8*
Shamus
Shamus is offline   Reply With Quote
Old 03-02-2010, 10:42 AM   #23
Rewards Points: 640
I feel what almost feels like air falling from the ceiling. its a wierd feeling it has vertical air flow... already tried covering the window and sliding door with that film stuff and it had no impact on the temp...
Old 03-02-2010, 11:36 AM   #24
Send a message via Skype™ to GarageDoorCente
Try laying a plastic down in the attic space, something to reduce the airflow.
GarageDoorCente is offline   Reply With Quote
Old 03-15-2010, 01:37 PM   #25
Rewards Points: 640
Well I found two sources of air coming in... around the window and sliding door in the room the trim had gaps where they came together at angles... and when it was really windy out this past weekend, I could feel air rushing thorugh the gaps... turns out they never foam sealed the gap between the window and the frame... doesn't explain the other air flow though from top down, but hopefully a vapor barrier will fix that
Hot Water Turning Cold - Could it be the washer/dryer? kissiffer4 Plumbing 3 01-28-2010 04:47 PM
Cold air return questions ekulrenlig HVAC 19 10-09-2009 01:44 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
Cold Rooms MNT Introductions 1 01-06-2009 12:37 AM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 08:05 AM
