Old 10-05-2012, 01:10 PM   #1
Cold room air vents
We recently bought a house with a cold room under the front veranda.
Freezing in the winter, very hot in summer, not sure what to do.
Also the vent for the room, I must close and open from the outside. Builder tells me this is correct. The vent is not fitted correctly and we have a spider problem along with water.
Can anyone tell me how this should be installed. I live in Canada.
mfavaro is offline   Reply With Quote
Old 10-06-2012, 06:05 AM   #2
Cold room air vents
I'm not sure. Do you have a picture of the vent?
Gissle is offline   Reply With Quote
Old 10-06-2012, 07:28 AM   #3
Cold room air vents
Exactly what vent are you talking about? Is it possible this room was added on? Sounds like it's simply not insulated.
Old 10-06-2012, 08:45 AM   #4
Cold room air vents
This is a simple plastic type vent cover for a hole in the foundation. The ventilation is for the cold room. However in order to open and close the vent I must go outside. Question is it on backwards? should I not be able to open and close from the inside
Old 10-06-2012, 09:28 AM   #5
Cold room air vents
It sounds like you're talking about a crawl space vent. If so, it isn't "ventilation for the cold room." Whether open or shut, it should have little or no effect on the temperature in that room. And no, it's not on backwards.
Old 10-06-2012, 09:40 AM   #6
Cold room air vents
So they have added this vent to my cold room, are suggesting they have put on the wrong vent.
Old 10-06-2012, 03:17 PM   #7
Cold room air vents
No, you are not understanding. If that vent is indeed for your crawl space, it has absolutely nothing to do with the temperature in that cold room. Some jurisdictions require crawl spaces to be ventilated. Please answer the question: is there actually a crawl space under that room??
Old 10-09-2012, 12:44 PM   #8
Cold room air vents
Is your basement finished or unfinished?
Rewound98 is offline   Reply With Quote
Cold Storage Room Help Gwen4280 Building & Construction 12 08-07-2011 01:34 AM
Cold Room Insulation dgoosen1964 General Discussion 2 11-10-2010 10:14 PM
Warm and cold air only coming out of 4 vents in whole house petergreen HVAC 5 02-03-2010 04:54 PM
Cold Room mikelbeck HVAC 14 01-16-2009 09:21 PM
How many heating vents needed per room? AllGoNoShow HVAC 4 01-23-2007 05:06 PM
