Cold Room - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-16-2008, 02:22 PM   #1
Cold room
Dont know if this is a heating question or not. The room on the northeast side of my house is significantly colder that the rest of my house. We have a 3 bedroom ranch built in 1951. The basement is dry and usually warm. The insulation in the attic seems ok, but looks older. We live in northeast Ohio and winter is on its way. Any info would be great.
Bigdaddyt is offline   Reply With Quote
Old 11-16-2008, 03:30 PM   #2
bradnailer's Avatar
If the room doesn't have a return vent then the air can't circulate properly, especially if you close the door.
bradnailer is offline   Reply With Quote
Old 11-16-2008, 05:44 PM   #3
if its like my nor/east room, not getting much sun in there. You should check the small things first. Are the windows leaking?, any drafts coming in, check outside wall outlets, any draft, use insulation that goes just under the cover plates. Before, my boys were great for telling me that its cold in their room but of course they needed the window cracked a bit for fresh air, go figure.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 11-19-2008, 05:41 AM   #4
What kind of floor is in that room??? Is there enough insulation under it???
mikebmore is offline   Reply With Quote
Old 11-19-2008, 11:36 AM   #5
Builder/Remodeler
mpepin's Avatar
Air leakage, insulation, and lack of sun are all possible culprits. What type of heat do you have in your house?
mpepin is offline   Reply With Quote
Old 11-19-2008, 11:53 AM   #6
I would look at the supply of heat to the room first. What size pipe, what size vent in the room, location of the vent (floor, wall, ceiling).
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Cold Room Right Thinking Kinda Guy HVAC 3 07-01-2008 04:35 PM
What is cold room for? KUIPORNG Remodeling 4 04-26-2007 05:06 PM
My kids room is cold snmhanson HVAC 5 12-20-2006 11:51 AM
