Is Cold Jointing An Issue With Brick Laying? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-29-2010, 04:03 PM   #1
Rewards Points: 1,062
Question
is cold jointing an issue with brick laying?
i was gonna build a little brick wall and was wondering if it's OK if i do it in several cold-jointed batches. i am hoping cold jointing is not an issue in brick work, like it is with concrete formations.
Old 11-30-2010, 07:59 AM   #2
Concrete & Masonry
Rewards Points: 620
What you want to do is just fine.
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
amakarevic (11-30-2010)
Old 11-30-2010, 09:26 AM   #3
Rewards Points: 1,232
If it were you would never see anything bigger than a firepit built of masonry.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
The Following User Says Thank You to Tscarborough For This Useful Post:
Old 11-30-2010, 09:39 AM   #4
Exclamation
LOL i was actually thinking the same thing but just wanted to confirm. THANKS BOSS ...
Old 11-30-2010, 10:29 AM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,636
Ayuh,.... Go for it,... Every brick is a cold joint,...
Bondo is online now   Reply With Quote
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Cold and Hot Water Issue westendmedia Plumbing 4 12-29-2009 08:41 AM
Brick Patio Issue Jfreres General DIY Discussions 1 07-29-2009 09:39 AM
cartridge faucet problem. drewhart Plumbing 4 01-15-2009 10:49 AM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 07:17 AM
