Cold Floor Near Dryer Vent - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-13-2012, 08:59 PM   #1
Cold floor near dryer vent
Hello,
I live in a condo with concrete walls and floor. Our dryer exhaust is located underneath our balcony. During winter, our floor gets really cold in line with the dryer exhaust -- my guess is that cold air is coming through the vent.
What can I do to avoid cold air coming through the exhaust vent?
Thanks!
gabrielr is offline   Reply With Quote
Old 10-13-2012, 09:13 PM   #2
Rewards Points: 13,300
There's suppost to be a flapper of louvers in the part of the vent sitting outside stopping air from getting in. May be stuck or need to be clean.
The hole though the wall also may not be seal or the insulation got pushed out of the way inside the wall when they made the hole.
Old 10-13-2012, 10:01 PM   #3
Rewards Points: 3,426
And if that doesn't work,get one of these.
http://www.amazon.com/Pasco-Louvered.../dp/B0002Z1H46
Canarywood1 is offline   Reply With Quote
Old 10-13-2012, 10:16 PM   #4
Residential Designer
AndyGump's Avatar
Rewards Points: 664
Send a message via Skype™ to AndyGump
Stuff a cat in the exhaust?
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
The Following User Says Thank You to AndyGump For This Useful Post:
mae-ling (10-13-2012)
Old 10-14-2012, 06:46 AM   #5
Rewards Points: 3,130
I wouldn't get one of those. Birds have a habit of building nests in them (yes, they can get in - it has happened to me). There is a vent that is similar but has a cover to block critter entry.
Old 10-14-2012, 11:45 AM   #6
AHH, SPANS!!!
Rewards Points: 1,166
start at the outside and check to see if the vent flap is operable. go under the house and check for insulation around dryer vent duct, holes in foundation for drafts etc...the piece of insulation in the floor joist bay could have been removed for the dryer vent placement also.
oops, missed the concrete part, Thanks Joe. looking at it from the outside is the only way to see anything if the duct pipe is in the slab....
hand drive is offline   Reply With Quote
Old 10-14-2012, 11:55 AM   #7
Concrete floors and walls, hard to see under it.
hand drive (10-14-2012)
Old 10-14-2012, 06:44 PM   #8
Thats because you get the cheapies,get the one with a screen in it.
New dryer vent moisture n0c7 HVAC 23 10-30-2011 06:02 PM
Dryer vent butterfly damper safe? TryHard Safety 0 01-14-2011 02:21 AM
very clogged dryer vent. Not just lint catman Tools 4 04-20-2009 05:48 PM
Dryer Vent Cleaning handy man88 HVAC 1 01-07-2009 04:08 PM
Help, how & where can I vent a 2nd floor dryer? jaes Remodeling 2 06-28-2008 11:03 AM
