Cold Exterior Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-13-2011, 02:55 PM   #1
cold exterior wall
i have a cold exterior wall where my fireplace is this wall is adjacent to my garage if you go into the garage up inside the storage area you can see the back of my zero clearance fireplace with only a wrap around the fire place should this area be insulated ??
naugy is offline   Reply With Quote
Old 03-14-2011, 01:42 AM   #2
Rewards Points: 1,092
Sure sounds like it to me. "Cold wall" answers your question. How? Start with calling the manufacturer, and asking what is recommended. Likely, rock wool would be a good bet. You may be framing out a new, short wall.
The Following User Says Thank You to jklingel For This Useful Post:
naugy (03-26-2011)
Freezing storage room next to the cold room Van3 Building & Construction 2 01-23-2011 06:50 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
Hot Water Turning Cold - Could it be the washer/dryer? kissiffer4 Plumbing 3 01-28-2010 05:47 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 09:05 AM
