Old 12-09-2010, 06:18 PM   #1
Cold Basement Floor
Ok. I need ideas folks. Links to website or pictures help.
I am re-building a burned down home for a client. The basement has poured walls and a 4" slab. My client wants to finish a large recroom area but, has concerns about the floor being cold. How best to limit that cold feeling?
The slab is already poured.
Nucon is offline   Reply With Quote
Old 12-09-2010, 07:20 PM   #2
Concrete & Masonry
Cold Basement Floor
Carpet with padding.
jomama45 is offline   Reply With Quote
Old 12-09-2010, 07:32 PM   #3
Cold Basement Floor
thanks jomama. looking for something more though.
Old 12-09-2010, 07:46 PM   #4
Concrete & Masonry
Cold Basement Floor
How about green treated sleepers shot down with rigid foam in between, and covered with plywood?
They also have a system out called "dri-core" IIRC, but it is more expensive than the first system.
Old 12-09-2010, 07:50 PM   #5
A Little Of Everything
Cold Basement Floor
Under-tile floor heating system?
http://www.thermosoft.com/thermotile...FRBW2godLymJnQ
DrHicks is offline   Reply With Quote
Old 12-10-2010, 02:25 PM   #6
Cold Basement Floor
jomama - by using this method I would have two concerns. 1. how to correct a step difference at the bottom of the stair case and built up floor. Code would only allow me 1/4" difference from other riser heights. 2. I'm guessing I would have to raise the exterior door to sit flush with the built up floor.
DRhicks- I looked at the web site but didnt find any mention of this being used under carpet and padding. Any idea if this would be an acceptable use?
Old 12-10-2010, 03:43 PM   #7
Cold Basement Floor
I got the impression he did not want to use carpet.
Personally, I'd think this would be a pointless expense if you were going to carpet.
Old 12-10-2010, 04:12 PM   #8
Cold Basement Floor
I think you have a nearly impossible task. If carpet is not enough, and you don't want to raise the floor and foam it, you're in a tough spot. No matter what you do, if there is no insulation under the slab, you are going to be pumping heat down there. Bummer. We put lock-together hard foam blocks (like for a playroom) over a very cold slab and they helped a lot. Perhaps that and carpet/more pad will help enough. OR, use the radiant heat you install w/in plywood that has pre-routed grooves for the pex. That would be a minimal height change, but still you will be blowing heat into the earth pretty badly. No ideal solutions.
Old 12-11-2010, 06:37 AM   #9
Cold Basement Floor
I used this stuff after we had water in our basement.You can buy them by 4x8 sheets or the roll(which i bought). It is a little expensive however if you decide to put laminate down you can go directly on top of it eliminating the need for a subfloor.
http://www.cosella-dorken.com/bvf-ca...roducts/fl.php
zoolou is offline   Reply With Quote
Old 12-11-2010, 09:09 AM   #10
Cold Basement Floor
no matter what, the floor'll be cold reflecting ambient earth temp under the slab HOWEVER you can attach elec heating mats to the existing conc then cover w/polymer-modified concrete w/VERY fine aggregate,,, usually, because of $, its only done in bathrooms
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders !
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help
itsreallyconc is offline   Reply With Quote
Old 12-11-2010, 10:28 PM   #11
Concrete & Masonry
Cold Basement Floor
If the house is burned out and requiring vast work already, why not cut a new set of stringers & treads?
Old 12-13-2010, 09:28 AM   #12
Cold Basement Floor
Raising the floor is probably the best solution seeing the slab is already poured. The PEX radiant solution will probably be turned down because of the cost to install and operate. Although it would be one of my top choices.
Old 12-13-2010, 09:33 AM   #13
Cold Basement Floor
Oops, sorry. The flooring finish is still "undecided" but our discussions have been about installing pad and carpet. If the homeowner does go with carpet I'll push a moisture guard padding.
Old 12-13-2010, 09:45 AM   #14
Cold Basement Floor
Thats what I like about reaching out to this board. You get exposed to a new products and ideas. I never seen this product before.
Looks like using this product with carpeting requires a built up floor system. After reading the FAQ on their website it looks like a radiant floor system can be used as well. I know the client wants a click and lock laminate floor in their sunroom so maybe the woudlnt mind a laminate floor system in the basement as well. I'll have to bring this up in our next meeting.
Old 12-13-2010, 09:49 AM   #15
Cold Basement Floor
Yeah, the polymer will up the cost. The heat mats and controls alone will be a nice drop in the bucket too.
Question About Basement Floor Drains Mozart Plumbing 3 12-05-2010 03:19 PM
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 35 10-28-2010 03:01 AM
Basement Floor Variance Allowance When Installing Ceramic Tile june Introductions 0 10-26-2010 11:09 AM
Ugly Cold Floor in Basement Washroom Makes Wife Grumpy slydevil Flooring 7 02-11-2010 09:10 AM
How to fix cold floor - air intrusion from basement Leah Frances Building & Construction 4 01-13-2009 10:26 AM
