Old 10-07-2008, 11:59 AM   #1
the Musigician
DangerMouse's Avatar
Question
cold air return vent height. is there code?
guess the title about covers it. kc? anyone?
DM
oops, height from floor i should add
Old 10-07-2008, 01:22 PM   #2
concretemasonry's Avatar
First - It is not just a COLD air return, it is a return for air and circulation.
The height is not a code item since it is dictated by the use.
For a basement, it usually is near the floor, since it will evacuate the cool air on the floor. This makes the floor warmer in the winter and reduces the load on the AC by circulating and making temperature more even in the summer.
If you are air conditioning, in some cases, a high return on upper floors is good because it sucks out the warm air and allows the cool air to fill the room. A low return on an upper floor will suck out the cool air, leaving the warm air to statify above depending on the location of the supply.
Returns and supplies should be coordinated and located properly for the functions/climate. If you have muntiple zones the locations could be different.
concretemasonry is online now   Reply With Quote
Old 10-07-2008, 01:59 PM   #3
the Musigician
guess i shoulda mentioned, it's not going to be a REAL return for air and circulation.
see this thread for more info, and thank you for the answer!---> Building a secret compartment
Old 10-07-2008, 02:08 PM   #4
Moderator
Termite's Avatar
Agreed, no code issues govern height. Locate it to optimize performance.
Old 10-07-2008, 02:53 PM   #5
the Musigician
oh, i think it'll perform all right.... heh heh 'bout half done now, will post more pics soon. =o)
DM
Basement Cold air return Bcoleman6 HVAC 2 06-07-2008 09:42 AM
move cold air return or add extra hot air CamL HVAC 2 03-26-2008 01:43 AM
Running network wiring in a cold air return vent? mcvane Electrical 26 04-19-2007 08:52 AM
Cold Air Return near ceiling or floor? jakobus HVAC 3 07-21-2005 11:54 PM
