Cold Air Coming Through Joist Holes In Concrete Block Foundation. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-27-2011, 06:13 PM   #1
Rewards Points: 79
Cold air coming through joist holes in concrete block foundation.
I felt cold air coming up through a hole in the floor that the cable cable comes through, so I went down to the basement and pulled down the sill insulation and see this:
That's a concrete block foundation/wall, the joists rest on 10" blocks and then it's 8" blocks up to the roof (yes, my house is made of concrete blocks). The joists go about an inch into holes knocked into the cavities of the 8" blocks. You can see the mortar that fell down down the cavity and out the hole during construction. I feel cold air coming in through thse holes. There may also be cold air coming down through the " inch gap between the finished wall and block (the gap goes all the way up to the attic but is covered by insulation up there) but it's difficult to tell for sure. Does this mean there is a leak to the outside somewhere? There's some cracks on the outside but no gaps or holes that I'm seeing. I've checked around several joists and so far it's the same. There is no insulation in the walls and it's January in Wisconsin so I'm sure the air in the cavities would be cold either way but you can see the cobwebs move so there is air movent. Could this just be caused by the difference in air temp?
Should I spray a bunch of expanding foam in those holes? Stuff in fiberglass insulation? Or do I have a bigger problem?
Ptron is offline   Reply With Quote
Old 01-27-2011, 07:35 PM   #2
Rewards Points: 4,790
unless you've got some foam-in-a-can hanging around, grab some f/g insulation & stuff the holes for tonite,,, even newspaper will work temporarily.
your furnace creates a draft & probably uses inside air for fuel combustion,,, kitchen & bathroom exhaust fans suck air out & create a negative air pressure situation,,, lots of ways heat can escape a house.
remember the old times when people stacked haybales & leaves about the foundation walls at ground level ? it wasn't for curb appeal
Old 01-30-2011, 04:29 PM   #3
I had a similar problem and I just bought a can of foam insulation and sprayed it to fill the hole - worked just fine!
Van3 is offline   Reply With Quote
Jacking and Sistering Floor Joist Captain.Sassy Building & Construction 17 08-11-2010 01:30 PM
Concrete Contractor and Masonry Contractor made a huge mistake homeowner12 Building & Construction 19 07-07-2010 09:37 PM
Framing over concrete foundation (above ground) rovers1973 Building & Construction 1 04-11-2010 03:49 PM
Re-using post holes in concrete philS Building & Construction 8 05-04-2009 08:15 AM
Footing for Block ontop of existing Fieldstone foundation. Concerns w/ work done.. slowjo Building & Construction 6 04-26-2009 10:17 PM
