Coffered Ceilings - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-17-2007, 01:20 AM   #1
Rewards Points: 1,088
Coffered Ceilings
What is the real benefit of these besides "architectural detail?" I'm looking at a house to buy and one has these in the family room and just makes the ceiling lower. I might remove them. How are they usually added to the ceiling? I don't think they provide any structural support.
handy man88 is offline   Reply With Quote
Old 10-17-2007, 11:28 PM   #2
kemerick's Avatar
Rewards Points: 87
They are almost always cosmetic as the span between them would be too abnormal for them to be structural. The easiest way to determine if they are structural is to get up in the attic and see if any roof supports go down to them. I bet not...
If you do remove them, you going to be re-drywalling or your looking at a massive amount of patching that will most likely sag or crack over time. Without seeing it I would say yes they can be removed, but you will be drywalling the whole ceiling in that area when done... which is however not a big deal.
My constant project is my home, my play time is usually spent on my CNC router.
kemerick is offline   Reply With Quote
Old 10-18-2007, 03:02 AM   #3
Thanks for your response. The coffered ceiling is in the family room on the 1st floor. There is also a second floor, so there's nothing to look behind to determine what is going on.
I wonder what type of material is used for the coffered celings. I would assume it's framed out (kind of like a tray ceiling) and the ceiling's faux beams are just drywall.
Old 10-18-2007, 06:11 AM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
General construction makeup of a coffered ceiling:
http://www.taunton.com/finehomebuild...-ceilings.aspx
- Build Well -
Texture coming off of ceilings mrswoodward General DIY Discussions 7 08-16-2007 08:42 AM
several problems while texture painting ceilings and walls carrotguy Painting 2 05-25-2007 04:38 PM
8 foot ceilings -- tray ceiling? lordlang General DIY Discussions 1 12-29-2006 07:09 PM
Vaulting my 8 ft Ceilings ALL CITY Remodeling 2 11-01-2006 05:33 AM
Raising The Ceilings propain Building & Construction 2 06-28-2006 06:33 PM
