Coffered Ceiling - 8ft - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-26-2010, 12:23 PM   #1
We are renovating our kitchen - as part of that we are taking down a supporting wall and need to have an 8 inch beam put in. Our designer is proposing a coffered ceiling to hide the beam - it would come down 8 inches and would be the width of the counter top (I think about 30 inches). My concern is that it will make the room look very small. The room itself is about 13 ft x 12 ft. Can someone comment?
Sheri is offline   Reply With Quote
Old 03-26-2010, 02:06 PM   #2
firehawkmph's Avatar
Rewards Points: 1,822
Sheri
Normal soffits in the old days were usually 12" down from the ceiling and 14" out from the walls. So at an 8" drop, you are less than that, but the 24" out seems a bit wide to me. Do you have to come out that far to enclose the beam? any way of recessing the beam up into the ceiling? When we do trayed ceilings in dining rooms we usually drop them about 8" and come out from the wall about 18". So you are not really too far off. Coffered ceiling usually refer to the inset vertical sections being on an angle. Not my favorite for a kitchen, but that's personal preference. I would probably go the trayed route and put a small crown up in the inset to go along with a small crown on the cabinets.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 03-26-2010, 06:14 PM   #3
to me a coffered ceiling is a grid work over the whole space. is it that or just boxing in a beam
The older I get the better I was
Old 03-26-2010, 09:09 PM   #4
TP,
You are correct. I made a mistake on my terminology. I had to look it up. Trayed ceilings can have either sloped verticles or square steps. My bad.
Mike Hawkins
Old 03-26-2010, 09:29 PM   #5
remodeling pro
Is this only on one wall, like an oversize furr down, or complately around the perimeter of the room, which would then be a cofferred/tray, whatever you want to call it, ceiling? I would try to come out a little less if possible, but we have had to do some that wide on renovations due to existing plumbing, ducts, etc. My theory is that you have to make them look like they have a design purpose meaning we install recessed lighting in them and trim the inside with a nice crown molding.
troubleseeker is offline   Reply With Quote
Tags
8ft ceiling , coffered ceiling
Coffered Ceiling Help trae73 Off Topic 3 02-14-2010 08:53 AM
Coffered Ceiling - 6 sections or 9? dlee1964 Carpentry 2 02-07-2010 11:40 AM
coffered ceiling FX4 Carpentry 10 12-07-2009 09:17 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
