Code Violation? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-15-2010, 03:33 PM   #1
Code Violation?
I want to put a recessed light between the joists in my ceiling, no biggie right? However, the light would split a copper hw pipe currently residing in the middle of the two joists. The gap between the power box and actual can is where the copper pipe would reside (split the uprights). Is this a big no no or code violation. I am desperate for room and I would really love for this to work. I dont feel like rerouting a hw line over 6in.
rdtour is offline   Reply With Quote
Old 01-15-2010, 04:02 PM   #2
Remodeling Contractor
If this light is an IC type and can fit into this space than there is no code violation.
Old 01-15-2010, 04:07 PM   #3
What do you mean by split the hw line ?
Will it touch the hw line ?
If not no problem, if it will you may get vibration
Old 01-15-2010, 04:16 PM   #4
Too Short? Cut it Again!
Just a thought. I think it dangerous for any of us to be commenting on building codes, knowing only those where we are, and not were you are. Some are common but not all.
Where are you?
Old 01-15-2010, 04:31 PM   #5
I did not p/u the ic rated one, they were out at my local hd. I live in illinois. the copper pipe does not touch any part of the light assembly, there is an 1 1/2 between the power box (splice box) and the light fixture (its one assembly). The copper pipe splits it. Now I did not consider water hammer or vibrations. But I've been working down here a lot and have not noticed any vibrations. Its just a hw to a sink in the half bath. I know I have to be 3" away from insulation since its a non ic fixture. But I figure copper is not very flamable is it? Plus, it'll help warm up the water in my HW pipe right?
At this point, I'll just give her a shot and see if my city inspector will pass it come next inspection. Thanks all for your advice!
Old 01-16-2010, 07:12 AM   #6
Where are you?
Codes have some variances, but follow the same idea of safety for humans and from fire hazards. Electrical codes are written by the fire protection agency. Cananda has some differences, but are based on USA NEC code to the most extent. You are correct, code in my area is slightly (possibly) different than in IL. But the issue is that the OP is proposing a safe installation.
Old 01-16-2010, 09:47 AM   #7
Framing Contractor
Call your inspector and ask.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 01-16-2010, 10:07 AM   #8
Come visit Bob. Inspections can be nightmarish here. In Champaign it was up to $30 an outlet for the inspectors to come out and plug a circuit tester in.
I cannot do any electrical work on projects anymore unless I know a licensed electrical contractor that will sign off on my work. Fortunately I do, and they know my work.
I understand the goal of the OP to just do something safe. That is not enough where I am anymore. And probably for good reason. I have unraveled some crazy things DIYsers have done when it comes to electricity.
I say again, I don't think any of us should be commenting on how to meet code, when we do not know it specific to the poster's location.
Old 01-16-2010, 10:14 AM   #9
Learning by Doing
Leah Frances's Avatar
I'm a lawyer and I no longer practice law because I got sick to death of all the CYA. The forum provides this:
I think this is enough.
I hope that people knowledgeable about safety and code issues continue to contribute their valuable comments and experiences (no one's getting paid, right?) without having to couch every single comment with some BS disclaimer.
Keep up the good work.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 01-16-2010, 10:31 AM   #10
I think I can offer safe advise on electrical code issues. I have had an electrical license since 1968 and held E1 masters license in 7 different states. I am aware of the differences.
Sold condo just realized it had a code violation Dave0009 Electrical 41 12-06-2009 07:45 PM
Lights in same joist space with water pipes - Code violation? jweller Electrical 2 03-15-2009 01:02 PM
Help With Code Violation pchicago Electrical 35 10-21-2008 02:23 PM
Building code violation fetzo Building & Construction 18 03-22-2008 02:42 PM
code violation? krw1957 Electrical 6 12-11-2007 06:16 AM
