Code Requirement To Replace Bathroom Window. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-29-2006, 04:51 PM   #1
Code requirement to replace bathroom window.
My local code is the IRC 2000 ready to adopt to the next edition. I am replacing existing aluminum single-glazed windows and siding throughout within the next month. There will not be any changes to the size of the existing openinigs, so a permit is not required by the AHJ.
The specfic area in question is a small (5'x8') master bath . The existing window to be replaced is 24"W x 42"H slider. As far as I know, the Code requires 3.0sf light & 1.5sf vent. I do not presently have an exhaust fan in this bathroom, but plan to install one.
Questions:
1. I am considering replacing the slider with glass block (acrylic) instead of a new $$$ energy window unit that will probably never be opened. Do I still need to have an operable vent in the glass block if I install a fan?
2. I also have near future plans (+ year) to enlarge this bath to 2x its size. Will the Code require that I increase the light & vent requirement when I remodel the bath?
Thank you.
Rem8 is offline   Reply With Quote
Old 10-29-2006, 05:58 PM   #2
Some codes require a window (some say it must open, others don't) in a bathroom. Most codes I have seen require an exhaust fan if there is no window. Since we do not know your locality, it would be best to check LOCAL codes for the answer to your question. When you do the future remodel, all codes existing then will need to be adhered to.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 10-29-2006, 08:56 PM   #3
Building inspector
inspects's Avatar
Originally Posted by Rem8 View Post
Questions:
If your municipality is going to be using the 2003 or 2006 IRC a window is not required with mechanical ventilation.
inspects is offline   Reply With Quote
Old 10-30-2006, 06:36 PM   #4
remodeling pro
You should not need a operating window in the bath as long as there is proper mechanical ventilation. I would check with your local code enforcement to be sure, because there are lots of quirks in the numerous codes, and they may use one that requires a window.
troubleseeker is offline   Reply With Quote
Old 10-30-2006, 06:54 PM   #5
General Contractor
Not sure where you are. In MA you have to have mechanical ventilation with or without a window. If you are putting an exhaust fan in the window does not have to be operable. Just make sure the exhaust fan is large enough for the bathroom and it exhausts outside.
Hammatime is offline   Reply With Quote
Old 06-16-2008, 02:57 PM   #6
Thank you all. Project completed iaw/CODE
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 03:34 PM
window in bathroom, or not? johnny331 Remodeling 18 08-10-2010 01:40 PM
cutting brick to add window in bathroom DoubleD07 Building & Construction 14 08-07-2007 02:05 AM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 04:49 AM
Window jamb helpless handyman Carpentry 11 08-03-2006 12:45 PM
