Code Question On Bolt To Footing Connection - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-07-2013, 04:09 PM   #1
Rewards Points: 35
Hi all, building my first deck here. One of my footings was poured out of line with the others (middle one). No idea how I did that! These are 12" dia footings and the one in question is about 3" off. My 1st instinct is to drill a new hole in the footing but how close to the edge of the footing can I do this?
Some other options that come to mind:
- bend the beam to make it fit 1.5"
- move all the other footings to make as centered as possible
- get a custom bracket?
Help!
dmk112 is offline   Reply With Quote
Old 09-08-2013, 02:20 PM   #2
Not so new
12penny's Avatar
Rewards Points: 520
I would probably try to adjust the others to get
that one a little closer to center. Doesn't really
matter that much, you'll be fine either way.
12penny is offline   Reply With Quote
Old 09-10-2013, 06:55 AM   #3
GBrackins's Avatar
Rewards Points: 2,108
check with the manufacturer of your post base connector. they have their recommendation/requirements for their products.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 09-10-2013, 07:31 AM   #4
joed's Avatar
Rewards Points: 12,878
Is that 2x the center of the other holes?
The hole in the bracket is elongated. How far off is it if you push the other ones in and this one out? I'm thinking just cut the slot bigger and slide it over. It looks like you have it pushed over the wrong way and have another 1" of movement to get the 2x inside it.
The Following User Says Thank You to joed For This Useful Post:
jomama45 (09-10-2013)
Old 09-14-2013, 08:10 PM   #5
Rewards Points: 35
Thanks for the all responses. Here's what I did after weighing options. I installed a 6x6 post base and filled it the gaps. Fits perfectly!
Deck Footing Question JDK1 Building & Construction 7 04-18-2013 09:26 AM
code question? yellowkid Building & Construction 8 03-03-2013 09:13 PM
Basement Remodel - HVAC Code Question buckybadger HVAC 2 08-16-2011 05:34 PM
footing drain question chrisk Building & Construction 2 09-02-2007 07:21 PM
code question JustJoe Building & Construction 3 01-27-2007 09:06 AM
