Code Hight For Railings - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-01-2006, 10:10 AM   #1
code hight for railings
Does anyone know the code hight for porch railings in massachusetts? it's a 1st and 2nd floor set of railings that I need to install.
thank you to all..
Bruce
falcon802 is offline   Reply With Quote
Old 07-01-2006, 12:18 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Smile
MASS STATE BUILDING CODE BOOK:
Section 1022.2.2 Height:
Handrails shall not be less than 34 inches (864 mm) nor more than 38 inches (965 mm), measured vertically, above the leading edge of the treads or above the finished floor of the landing or walking surfaces.
Exceptions:
1. Handrails that form part of a guard shall have a height not less than 34 inches (864 mm) and not more than 42 inches (1067 mm)
2. Handrails within individudal dwelling units shall not be less than 30 inches (762 mm) nor more than 38 inches (965 mm), measured vertically, above the leading edge of the treads or above the finished floor.
Hope this helps
- Build Well -
What's the ICC Electrical Code? Chuck Electrical 7 02-20-2013 10:19 AM
Code requirement to replace bathroom window. Rem8 Building & Construction 5 06-16-2008 02:57 PM
Another Bryant 383KVA with code 31 problems rpgIVguru HVAC 1 02-05-2007 01:47 PM
code question JustJoe Building & Construction 3 01-27-2007 09:06 AM
International building code and permits rforsha Building & Construction 4 08-28-2006 06:35 PM
