Coating/sealing Basement Dirt Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-28-2010, 09:16 AM   #1
Coating/sealing basement dirt walls
i own a older home with a basement. The foundation walls have exposed dirt-as this was somewhat common in older homes. the floor is concrete. i need to coat this exposed dirt with something to seal and keep down the earth smell/dampness in my basement. I am a realtor and once I saw a white coating-thick sealer in a basement on these type walls. any ideas thank you
loganc is offline   Reply With Quote
Old 08-28-2010, 10:40 PM   #2
Parging the walls is not likely to hold up. I would say you have 2 choices 1 build a form and pour concrete or 2 build concrete block wall.
hayewe farm is offline   Reply With Quote
Old 08-28-2010, 10:50 PM   #3
Concrete is the only way to go.
gjjr2001 is offline   Reply With Quote
Old 08-29-2010, 08:22 AM   #4
Rewards Points: 4,638
we'd install an air exchanger instead unless the dirt's objectionable then install 20mm vapor barrier, too
Damp basement walls cjjjer Building & Construction 1 04-02-2010 04:18 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
Sealing basement walls, and filling bigger holes 99miles Building & Construction 7 11-12-2009 06:37 PM
Reinforcing dirt walls in crawlspace Fix-It Chick Building & Construction 8 01-13-2008 11:57 AM
Removing cement walls in basement / replacing with I beam bbockstanz Building & Construction 9 11-19-2006 06:31 AM
