Cmu Wall With Gate Is Leaning - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-01-2008, 03:12 PM   #1
cmu wall with gate is leaning
i have attached 2 pictures so you can understand what i am talking about.
I am looking for any suggestions as to how to fix. You can see from the pictures that i have a clamp on the small wall so i can get the gate door to barly open.
it also looks like the long wall that is perpendicular is tilting slightly to the left.
Would some L brackets and cement screws work? or should i try to take the top blocks apart and build from the lower 3 blocks back up?
any suggestions or help would be most excellent.
I am in Phoenix az if that matters at all.
cmu wall with gate is leaning-img_4249.jpg   cmu wall with gate is leaning-img_4250.jpg
big_alaz is offline   Reply With Quote
Old 07-01-2008, 04:07 PM   #2
concretemasonry's Avatar
Rewards Points: 2,608
The walls look fine except they were not properly bonded or tied together.
The problem is that you have footing that is tilting or settling. - That is not an easy or quick fix.
As a temporary repair, attach large angles with big anchors well embedded in both walls. Depending on th the wind and moisture in the soil, it will work for a while.
concretemasonry is offline   Reply With Quote
Old 07-01-2008, 04:56 PM   #3
Rewards Points: 1,232
That is going to be a sidewalk at some point. CM, the wall will probably pull the gate-wall with it. There also appears to be a structural crack running horizontally along the wall.
At some point in the future, you will have to tear down that wall, or spend a lot of money to correct the foundation, or both.
Tscarborough is offline   Reply With Quote
Garage wall leaning out billdiy Building & Construction 11 03-22-2010 07:08 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
