Clubhouse Walls-imaginative Suggestions Wanted - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-10-2011, 07:53 PM   #1
clubhouse walls-imaginative suggestions wanted
i'm trying to cover the outside of a kid's clubhouse economically. i'm thinking about using exterior particleboard or plywood. if they are primed and painted, will they hold up/last? Is there another cheap wayu to cover the shell? the walls are 6x8' and 8x8' with various windows and a door. thoughts? imaginative suggestions?
jjjeno is offline   Reply With Quote
Old 04-10-2011, 09:19 PM   #2
Learning by Doing
Leah Frances's Avatar
Start looking at your local craigslist. I bet you could salvage/recycle lots of cool stuff.
Doors jump to mind. It would be cool to clad it in doors. Very club-house-y.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 04-10-2011, 10:56 PM   #3
In a little over my head
Rewards Points: 706
When I was building my hunting trailer/shack, I found some pre-primed, pre-painted exterior paneling. It seems like it was under $20 a sheet. Cheap and easy, once I figured the cost of paint.
ratherbefishing is offline   Reply With Quote
Old 04-11-2011, 08:26 AM   #4
Rewards Points: 1,528
T1-11 plywood is somewhat decorative (vertical grooves about 8" apart), is structural, relatively cheap, paints well, should hold up fine, easy to work with.
bob22 is offline   Reply With Quote
Old 04-11-2011, 08:38 AM   #5
Great ideas-keep em coming! As far as my original post, will exterior particleboard or plywood hold up if primed and painted? Thanks-
Old 04-11-2011, 08:59 AM   #6
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Nope.... it's intended to be covered with siding....
It'll last for a couple of seasons but that's about it.
tcleve4911 is offline   Reply With Quote
Old 04-11-2011, 11:29 AM   #7
how about the t1-11 plywood bob recommends- does that stuff last if painted?
What about my idea of getting 4' pieces of 2x6 from the home schmepot cull lumber section for 58 cents a whack and ripping them vertically and the putting the good side out to form, in essence, pine siding!!?
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 06:59 PM
Caulk on walls, priming, trouble with lines, and more! mrsjande Painting 7 09-10-2009 10:29 AM
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 06:07 PM
Need help with very ugly basement walls GrandmaStormy Remodeling 5 03-05-2009 03:43 PM
Moisture on walls chrisr Building & Construction 1 01-20-2008 10:37 AM
