CLR Stained My Concrete? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-30-2011, 01:46 AM   #1
CLR stained my concrete?
Hey guys. I was trying to remove a pot rust stain from my concrete patio and spilled the bottle of CLR. I sprayed it down but it looks like it bleached the cement. The cement it regular, unstained, uncolored, unsealed, driveway/sidewalk type finish. The cement was poured 5 months ago and seems to be still curing so it's darker in some areas of the patio than others. Of course I spilled the CLR on one of the darker areas. Any help to fix this would be appreciated. Thanks in advance.
choopius is offline   Reply With Quote
Old 06-30-2011, 06:59 AM   #2
Rewards Points: 5,336
I'd try powerwashing the patio with the proper cleaner.
Did you try a stiff bristle brush with a detergent?
Ron
B. Franklin 1759
Old 06-30-2011, 10:46 AM   #3
Well this happened yesterday so the "bleached looking" CLR stain is dry now. Should I still scrub it with laundry detergent? It also seems like some of the darkness is returning to the spot. Maybe it'll match eventually?
Uploaded with ImageShack.us
Here's a shot of what the still curing areas look like. Will the patio eventually be all the lighter color? It was poured about 5 months ago:
Old 06-30-2011, 11:02 AM   #4
I don't think the splotchy nature of the concrete pour is "cure" related.
On the CLR stain, what have you got to lose by scrubbing it?
Ron
B. Franklin 1759
Old 06-30-2011, 11:06 AM   #5
I thought putting water on it might make it take longer to dry out and hopefully return to the darker color. I'll try the detergent scrubbing idea in a bit though, thanks.
As for the "curing" my reasoning for thinking that was that the cement is darker in the places that get hit by sprinklers or moisture. Just figured it was taking longer to fully dry out. Do you think it'll just stay like that?
Thanks for the help.
Mulch dye stained concrete. EPERRINGTON Landscaping & Lawn Care 1 04-21-2011 08:57 PM
Creating a flat floor on an angled concrete floor? Magno Building & Construction 1 04-14-2011 05:42 AM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 01:56 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 11:12 AM
Concrete Contractor and Masonry Contractor made a huge mistake homeowner12 Building & Construction 19 07-07-2010 09:37 PM
