Closing In A Window - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-11-2008, 02:58 PM   #1
closing in a window
Hi everyone. I have a window in my bathroom approx 3x3. I want to close in. The wall is an exterior wall and concrete block. Would it be ok to just frame in with wood or would I need to use blocks to fill it in?
thanks,
Jacob
Jone is offline   Reply With Quote
Old 12-11-2008, 03:51 PM   #2
Registered User
Termite's Avatar
It would be best to use masonry. You see, your window is flashed and sealed to prevent entry of water. You could build some sort of wood insert and properly flash and seal it, but it would look goofy and wouldn't hold up as well as masonry would. A small masonry project like this wouldn't be too tough for a DIYer armed with a little knowledge, patience, and a few simple tools.
Old 12-11-2008, 04:29 PM   #3
Rewards Points: 5,336
What's the exterior siding?
Ron
Old 12-11-2008, 04:49 PM   #4
stucco.
thanks for the replys
Old 12-11-2008, 05:20 PM   #5
bradnailer's Avatar
Have you considered glass block for the opening? Might look kinda cool.
bradnailer is offline   Reply With Quote
Old 12-11-2008, 05:29 PM   #6
Originally Posted by Jone View Post
stucco.
You would definitely want to fill it with concrete block. The wood would shrink and leave cracks that would allow water infiltration.
Ron
Old 12-11-2008, 08:36 PM   #7
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
thanks,
Jacob
Are you sure this windows is not a fire egress?
Jamie
jamiedolan is offline   Reply With Quote
Old 12-12-2008, 12:43 AM   #8
Theres more then one way.
iMisspell's Avatar
Rewards Points: 150
Jamie
This may change from state to state, but i have been told (architect and local inspector) in NY (at least the local here) the bathroom window does not matter and if you have a vent fan, no window is required.
~ What was once an opinion, became a fact, to be later proven wrong ~
My current learning experience - 22x22 addition - Work shop, music-room, master bedroom above..
iMisspell is offline   Reply With Quote
Old 12-12-2008, 01:13 AM   #9
DIY'er
jamiedolan's Avatar
Glad to hear you checked on it.
Jamie
Old 12-12-2008, 12:16 PM   #10
fhi vinyl windows
fhivinylwindows's Avatar
Rewards Points: 150
That's a really good idea.....I'm glad that I read your reply before I posted the same thing. With Glass block the outside of the house will not look like a patch job.
fhivinylwindows is offline   Reply With Quote
Keeping Egress Window Code Compliant ClnlBrahm Building & Construction 2 09-11-2008 10:00 PM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 10:47 AM
Shower in Window jchri66 Remodeling 1 05-27-2008 12:50 PM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 02:41 PM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 04:49 AM
