Old 10-30-2008, 04:27 PM   #1
Closing In Garage Door Opening
I hav the garage on my house that i'm converting into a master sweet. the floor is concret is thier any easy safe way to lay block on the exsisting doorway concret and install one and a half block to make sure it is water proof other then breaking it up and burrying one block and taring. i no i can put it in a bed of like hydralick cement but i'm not sure if this is adiquit its been a long time since i laid block.
all vinyl is offline   Reply With Quote
Old 10-30-2008, 05:04 PM   #2
If it was me I'd rent a concrete saw and cut through the slab between the inside corners of the existing block at the door opening, remove the strip of slab and put the block on the footing or stemwall.
Old 10-30-2008, 06:21 PM   #3
i have the saw but just littel lazy looking for an eaysier way thanks
Mold in detached garage jkrodger Building & Construction 15 05-01-2009 02:46 PM
Light Switch to Detached Garage - Grounding Issue smitty286 Electrical 1 10-22-2008 01:17 PM
double car garage slightly uneven... mcvane Building & Construction 6 11-25-2007 09:41 AM
Garage Door Opener - Noisy on Closing ? quantass Electrical 2 02-13-2006 03:09 PM
