Closet Construction - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-26-2008, 07:37 PM   #1
Smile
closet construction
We want to put a linencloset into a small bathroom. We willhave to into
the bedroom next door. The wall is not loadbearing. We just don't how
to begin or end. help please.
bunnyhop is offline   Reply With Quote
Old 08-26-2008, 09:47 PM   #2
Registered User
Termite's Avatar
Just to be sure, are you 100% certain that the wall you're wanting to move is not load bearing? Gotta make sure!
There's a few skills involved in this kind of project.
You'll have to carefully demolish the wall you want to move, and plan on moving the electrical in the wall. This will leave a void in the flooring that must be dealt with. You'll frame and wire the new wall, and will sheetrock and finish the ceiling where the old wall was. Then you'll have to sheetrock and finish the wall. Then you'll have to trim the wall and door opening.
Quite a bit of work for most people. If you're confident that you're not biting off more than you can chew, we're here to help you along the way.
Old 08-27-2008, 12:48 PM   #3
Smile
Thanks Kctemite. We will consider having someone else do the work.
bunnyhop
Hardwood closet threshold question DIY-Renovator Flooring 1 07-27-2008 04:42 AM
Annexing service closet former33t Building & Construction 1 01-13-2008 01:29 PM
Musty smell from closet after leak Musty General DIY Discussions 2 09-10-2007 08:36 PM
Want to build closet in attic. Need advise. mbrittb00 Building & Construction 1 11-14-2006 06:58 PM
