Closet - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-17-2012, 10:24 PM   #1
closet
I have two adjoining bedrooms 10' wide x 15' long , as you can imagine I don't have much room. can I build a closet that both rooms can share? the dividing wall is a 2x4 studded.
Im looking for ideas to design it.
thanks for any input
Level
Level is offline   Reply With Quote
Old 01-17-2012, 10:33 PM   #2
Rewards Points: 12,878
Not a great idea. How's that going to work when someone open the closit and can see right through into the other room if the doors are both open?
A closit can be as narrow as 18" deep. Far better to just build one on each side.
Old 01-17-2012, 11:17 PM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Use the whole wall (if it's the 10' wall) for a closet and put a divider wall in it, making 2 5' closets.
titanoman is offline   Reply With Quote
The Following User Says Thank You to titanoman For This Useful Post:
mae-ling (01-18-2012)
Old 01-18-2012, 01:15 AM   #4
Rewards Points: 2,202
Center the closet between the two rooms,so 12" each side of center.
mae-ling is offline   Reply With Quote
Removing existing closet gnomonklater Building & Construction 4 12-02-2011 01:14 AM
Framing a new header for closet opening jmai14 Carpentry 6 07-09-2011 03:20 PM
Laundry closet decision LClark Remodeling 2 06-26-2011 07:19 AM
Hardwood closet threshold question DIY-Renovator Flooring 1 07-27-2008 05:42 AM
Musty smell from closet after leak Musty General DIY Discussions 2 09-10-2007 09:36 PM
