Closed Cell Spray Foam And Terminates. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-19-2011, 08:57 PM   #1
gkaro's Avatar
All,
building an extension on piers /sonotubes. About a foot off the ground. I need to insulate from the top down cause it is too low to do it after.
I've laid 1/2 " pt plywood between every joist at the bottom. I plan on spraying 2" of closed cell on top of the ply and filling the rest with bats.
Does the spray foam pose a hazard here with terminates?
gkaro is offline   Reply With Quote
Old 12-19-2011, 09:02 PM   #2
Msradell's Avatar
Rewards Points: 338
Not sure about the termite issue but it would seem like they would attack the plywood first anyway. Says you're going to setup to use spray foam why not fill the entire cavity with it? Certainly provide better insulation in the long run. Posting your location would also help us provide better answers.
Msradell is offline   Reply With Quote
Old 12-20-2011, 06:47 AM   #3
gkaro's Avatar
Seems odd I know. Cost.
4" of closed cell spray here cost about 4/sq.
Getting the air barrier with foam and the rest of the R with bats is the overall best $ method.
Old 12-20-2011, 07:06 AM   #4
Rewards Points: 1,500
Terminates? Termites sent back in time to kill John Connor? That works.
mikegp is online now   Reply With Quote
Old 12-20-2011, 07:27 AM   #5
gkaro's Avatar
Darn auto correct...
Haha
Old 12-20-2011, 09:54 AM   #6
AGWhitehouse's Avatar
carefull putting a closed cell foam barrier on the exterior of the envelope. 2" thickness of 2.0lb closed cell is a class II vapor retarder. If you do that, make sure not to provide one on the interior side or you'll be creating a double barrier system.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 12-20-2011, 11:31 AM   #7
gkaro's Avatar
That's what I thought as well. My inspector IS asking for poly on inside as well. Not sure of the process to dispute. These guys want you to admit that 2+2 is 5
Old 12-20-2011, 08:02 PM   #8
read up on your local code. In CT code allows for the vapor barrier to be located at the exterior of the assembly only if there is a continuous layer of R-10 foam insulation. If there is not a continuous layer then you will need to provide a vapor barrier at the interior of the thermal envelope and provide only enough foam to create an air barrier and NOT a vapor barrier.
Old 12-20-2011, 09:22 PM   #9
gkaro's Avatar
What would continuous mean. Is spraying between studs continuous or does the "break" at each stud break that continuity?
Thanks for your help.
Any Canadians familiar with the Ontario code for this issye, id like your input.
Old 12-21-2011, 09:05 AM   #10
Yes, studs or joists are considered breaks. Think of like putting a layer of foam on the outside of a wall before putting up siding. Same would apply for a ceiling or floor system.
