Old 10-28-2009, 03:22 PM   #1
Default Closed Cell Spray Foam with Fiberglass?
We are in the process of insulating our attic which has been remodeled. I was looking to use closed cell spray foam for insulation, but the price is more than we can budget for.
It was proposed to use 4" closed cell spray foam and use R-19 fiberglass insulation over the foam to our attic catheral ceilings to meet the code of R-38. The gable ends would be R-20 with 4" of foam
Has anybody gone done this or recommend it? I am new to all of this stuff, and the price difference is within our range..
ddave23 is offline   Reply With Quote
Old 10-28-2009, 03:54 PM   #2
this hybrid method is a good way to get a good job done with less costs. Most of the air leaks are at the seams and edges and the foam does a good job of sealing these.
Bob Mariani is online now   Reply With Quote
More On This Topic
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. R-Value is the ability of insulation. For instance, right here we are tempting to create two... Read More »
On behalf of Expert Village, my name is Gregg Tauriello. I'm from Suite 16 Studio, and I'm here to talk to you about soundproofing for a recording studio. Okay, I'm going to show you the inside of a standard wall. This is 2x4 constructions; this is a... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. The thickness of our insulation is going to make a difference in the R-Value. So if we have... Read More »
So, now that we've prepped the board and we've mixed up our Q-Sail, we're going to go ahead and apply it, and fill in that hole that we just prepped. So, what you do is you just take your squeegee and just kind of really, try to get it way in there, and... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. In talking about insulation, one area that we need to cover is how well your house is sealed... Read More »
Closed Cell Spray Foam insulation and hiring a contractor. Spud Building & Construction 2 10-14-2009 11:03 AM
closed cell vs open cell foam insulation amonalisa Building & Construction 1 11-06-2008 11:39 PM
Advice on closed cell/open cell spray in insulation 794613 Building & Construction 2 10-31-2008 09:56 AM
Q: Closed Cell Foam Thinckness stangboy68 Building & Construction 10 12-08-2007 12:30 AM
closed cell insulation in attic Dennis Doucette Building & Construction 7 03-16-2007 11:08 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
