Close In Opening Between Roof/rafters And Side Walls Of Cabin - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-15-2010, 12:49 AM   #1
close in opening between roof/rafters and side walls of cabin
I have a framed in cabin which I am putting HardiPlank Siding on (4x8 sheets). It is rustic and unheated in NE area. What do I do to close in open area under roof where rafters are, above exterior walls? Similar shed type building closed them in with 1x4's, one on side, one below, painted. Better to use manufactored soffit with venting for flat area and eg 1x4 for side edging? Saw suggestion of luann panel cut to fit flat area and board used for side area (sorry I guess soffit and fascia are right terms?) Never did this and on my own to finish it out...will be generally left unheated but occasional wood stove in winter in there...thanks much appreciate any advice...Gracie
Gracie is offline   Reply With Quote
Old 08-15-2010, 07:53 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 186
If you are going to have a flat ceiling instead of a vault you may need a cornice consisting of soffit, fascia etc. It is not an absolute necessity but does look nice and complete although many cabins have open rafters without cornice. If you want the open rafter look and have a flat ceiling then you will need to enclose and insulate the area you are talking about. The way you suggested is as good away as any. If you do have a vaulted ceiling though, you will need to have vents in the area between your rafters. I am not much on Luan (or however it is spelled) as it just don't hold up well.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
Gracie (08-15-2010)
Old 08-15-2010, 08:58 PM   #3
close in rafters exterior walls on cabin
hmm...the rafters are prefab so no chance of vaulted ceiling...will have to have flat ceiling... what is a cornice for an outside wall? Have heard of it eg around windows...I thought the luan board sounded a bit lightweight and perhaps would wear out/rot a bit. Would be glad to do cornice but can you explain what it is for me? thanks so much...
Old 08-15-2010, 09:22 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 186
here is a sketch of a cornice on the rafter tails or the part that over hangs the outside wall.
Jim
Gracie (08-22-2010)
Old 08-15-2010, 10:15 PM   #5
Rewards Points: 562
hardie
hardie plank makes regular soffit material also.
4just1don is offline   Reply With Quote
The Following User Says Thank You to 4just1don For This Useful Post:
Gracie (08-22-2010)
Tags
cabin , fascia , soffit , unheated vent
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 09:39 AM
Straightening Racked Walls smitty286 Building & Construction 3 03-11-2008 09:35 AM
Keeping Water out of the Top of Brick Walls o2barockstar Roofing/Siding 4 02-18-2008 03:50 PM
