Close In Garage Ceiling With Trusses On 4 Foot Centers? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-26-2010, 02:29 AM   #1
close in garage ceiling with trusses on 4 foot centers?
In this area o f Virginia we have a lot of pultry houses,and they use what is caled tryply with furring strips and plastic banding to hold up the insulation,it's an inexpensive way to close up,and insulate,can you give me some other ideas?
debbie estep is offline   Reply With Quote
Old 06-26-2010, 06:11 AM   #2
Nearly anything you install on a ceiling will need closer spacing than 4'. Furring strips at a minimum of 2', or 16", will support most any material. Depends on what the final use is. There are light weight plastic sheets available for farm buildings that are washable and stop the wind from blowing thru. The usual choice may be drywall, but that is very heavy, and not a good choice if the building is not heated.
Garage ManCave Please Help!!! ManCaveMark Building & Construction 7 09-14-2011 03:01 PM
880lb hoist from garage ceiling etriad Building & Construction 15 02-26-2011 04:18 PM
garage ceiling joists josh123 Carpentry 6 07-14-2009 11:07 PM
Garage ceiling has 2X4 joists-will it hold? markd Building & Construction 13 01-06-2009 02:46 PM
Question about ceiling joists in a garage allpraisebob Carpentry 11 12-14-2006 08:00 AM
