Close Call - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-19-2007, 10:40 PM   #1
Close Call
Just thought everyone migh like to see what could happen when you use the wrong size column. We were jacking up the floor to put an LVL shim bewteen the post and the beam when this happened.Luckilly no one or nothing was hurt, but it was amazing and scarry to see a beam with full load drop an 1/2. Luckily no on had their hand in between the post and the beam when this failed. From now on, I will only use the highest rated parts I can find.
smartin684 is offline   Reply With Quote
Old 02-20-2007, 05:36 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Thanks for sharing that....
FWIW - We use 6x6 posts - (more than one if necessary-so as not to put all the stress into one area of raising a beam) .....and the strongest-weight truck capacity bottle jacks we can find...never had a problem in 22 years of raising beams....
- Build Well -
Bathroom door always wants to close - Help? ldacpano Windows and Doors 8 10-08-2012 02:42 AM
why call it a 2x4? johnny331 Off Topic 37 04-08-2008 06:51 AM
Removing Wood Flooring - Cutting Close to the Edge of the Wall rgmetro Flooring 2 07-12-2007 06:21 AM
What to do? Who to call? Dusty General DIY Discussions 1 06-07-2007 03:58 AM
Shingles butted too close together? itwerx2 Roofing/Siding 8 04-28-2007 03:35 AM
